when to replace timing chain?
Susan76
Finally fired my 76 302 C4 from a 10 month overhaul and mods... what has been done?? well from the front winch to new cover on the spare tyre -- lots... complete new wiring harness with 16 circuits from headlights to taillights+++ new seals everywhere except the balancer. Edelbrock Performer with Holley 470 Truck, reman 1970 single point dist. 23 gal tank with SW elec fuel pump at the tank - filters before the elec pump (2" from the tank outlet) and at the carb. MSD old school coil (circa 1970 left over) Taylor 8 mm wires & Motorcraft plugs. Rad tanked & rodded. Timing at abt 2* when I fired it the first day (eyeball). It was running good and started in what seemed to be 1/2 revolution - hot or cold.
few other items C4 rework with deep girdle pan, locker rear, tru track frt, driveshaft, 140 map alt isolated to dual batteries for the Warn VR10K, Lowrance GPS, Corbeau seats, onboard air, frt & rear cameras, halogen & LED lights frt & rear++++++++
Fire it up after prefilling the carb to check floats. I wasn't able to drain the block so I fired it "semi dry" as I wanted to get it out to run coolant cleaner through it and flush it a couple of times before hooking up my new heater core. Did about 8 short warm up and cool downs as I checked trans fluid (complete drain inc converter and new cooler), ps etc to get all the air out. Finally added coolant and ran about 1/2 hr a couple of times. I had set my new T steering with a tape measure so first drive was directly to the alignment shop. maybe 2 miles.. Got there and it started stalling. Had to left brake to get it on the rack and off. Took it for a 20 mile drive - about 12 hghy and rest in town... some times it would buck and a couple of times or stalled after taking off from stop signs like no fuel. Had to feather the throttle to keep it going but then good for a couple of miles. When it stalled, it started right back up 8 out of 10 times. Couple of times trying 1/3 1/2 throttle it would chirp the tyres going into second and no nosing over in 2nd. Got home after picking up cleaner for cooling system and it would barely run.
In the shop, timing reset to 6* and I realize the mark is "bouncing" 4-6*. Could barely keep it running -- so check timing - check floats - check firing order and it keeps getting worse... Pulled the carb bowls looking for anything that could get past the filters (or from Holley). Replaced the filter at the tank which had picked up apparently loose stuff in the tank. Tank had been in place & dry since last sept. I even bought a new gas can for the first gas to go into it.... Set to pointer at 20* and hand on fan cranked back until the rotor moved and it seems like about 6-8* of "slop" as I did it 3 times.
Any idea what is the tolerance on a sm block timing chain? I am going to grab the carb off one of my 428s and try it just to replace the "new" Holley with a known working one.
Suggestions?
Susan
broncnaz
6-8 degrees of play is nothing a new timing set can have close to that. Personally I like to change the timing chain at around 100K but they will go longer although some of the mid 70's timing chains used a nylon gear and they can break
I dont believe you have a timing chain issue tho. It could be that 70's points dizzy. Id double check the points gap and condition of the points also check the shaft for side play. As that commonly leads to jumpy timing.
Another ignition related possibility is did you install a ballast resistor in the wire going to the coil? if not it needs one. Also that old coil could be weak or bad even.
What he said mostly, though I always went by the feeling that even though perhaps not completely shot, 8 degrees was still fairly loose on in the chain department.
And what about the cam? Is it new or is this the original engine internally? If so, how many miles?
Do you have a fuel pressure regulator and/or gauge hooked up? Some electric pumps like to put out a little too much sometimes. Just had that discussed in a thread here last week in fact.
Are you running the vacuum advance? If so, which port on the carburetor is it connected to?
Points can wear quickly when new, and a condenser can fail without notice and mess with your points too. Especially if the reman'd distributor had an old one put back in.
Back to the timing chain thing, we just installed one a few weeks ago and it only has about 10 miles on it so far. I'll check to see how many degrees it has in it.
Just out of curiosity
Good luck. Hope it fixes itself while you're asleep! I like those problems ;D
Oh, and welcome to CB.com too by the way! Good to have you here.
WheelHorse
Susan, bump your base timing to 10. If you experience a little ping you can always back off the advance if your canister is adjustable. Otherwise you'll have to back the base down or run a higher grade of fuel.
Adjust each idle a/f screw to achieve the highest idle and then go a tad richer which is CC. You're probably lean. If you starting turning clockwise and it starts to die down, then try CC and see if the engine responds by raising RPM's.
PS I had 8 degrees of slop on my stock '77 and it ran as fine as a fuel injected car.
Seeing that I have my engine out, I will put a true roller timing set on her and bring that slop down to near zero, but regardless, my engine still ran smooth with the slop.
bax
Old Member
Pull your fuel pump off and check for slop. if your really worried.
Susan76
Susan76
not used to small blocks
Broncnaz & Paul & Wheelhorse
Thanks for the replies. This is my first small block since about 1976. That was a 72 bronco 302 C4 that was stock other than a Holley 4412, shift kit, rancho suspension & some BFG mudders. So its been a long time. 427 & 428s is where I spend my time. I am used to 2* max on a chain or change it with a new Cloyes. Theory behind my Bronco is old school reliability - no electronics to fail in the middle of nowhere as I travel alone in the SW deserts. Fix it with a jack knife and matchbook. Dist is stock circa 1970 AutoZone reman w/ vac advance to ported vac on the carb. Its been unhooked since I brought it back into the shop. Coil was NOS from my old shop - think I have 2 more left and yes the ballast resistor is there.
Current timing chain.. who knows... Engine wasn't for a 76 from lack of smog on it. I made the decision last summer not to cam it as I was forced into doing so many other things and did not want to get into cam brake in. Should have just gone roller but been thinking I want a 351 for the stroke was also on my mind. Just real hard to find where I am. -- Small town middle of nowhere. And new to these small blocks.
I've rechecked and reset the points - dwell was high - 38*. Now 32* I've tried the timing swung probably almost 40*. Played with float levels - hate these needle and seat assemblies where the needle isn't "locked in" - took idle air adj in and back out 1 1/2 turns.. what gets me the most is that it ran so well for the first 1 1/12 hrs just startups & moving it in my driveway to get the air out of the tranny & ps. It is a large driveway and I can do complete circles without coming close to the sides. It wasn't until I took it to the alignment shop that it started running badly. Coincidence????
First time out on the road speed to 30.. school zone.. one right and then one left turn at a stop light. That is when it started "missing". Thought possibly the idle was too low - 650 in park. Alignment shop is on the edge of town so when they finished I headed out of town to see what it would be like on the open road. A couple of "stumbles" but no problem until I turned off to a side road and came to a stop sign, took off and it died. Started right up and ran to the next one and did the same. 4th one it had to crank for a minute and a half. Went back to the main road where I feathered the throttle to get up to about 60. But it ran fine back to town. Stopped to get cooling system cleaner and one other place and had to left brake but sometimes it would be just fine to the point of chirping the tyres going into 2nd gear....... I'll pull the carb off my 69 CJ tonight to see how that carb reacts. Its never let me down in 45yrs. And what did Spock say...... Boldy go....
Rustytruck
650 in park is way to low. you want at least 700 in gear holding the brake. almost 900 in park. Bronco's have resistor wire for the coil in the stock wiring harness. You do not use a seperate resistor or a coil with a resistor in it. With your wiring change recheck how you are handling the coil resistor. Make sure your not double resisting the coil if you added another. I worry the 76 should have duraspark ignition. If you do, ohm check the magnetic pick-up in the distributer. I dont worry about timing chains until I see about 15 degrees of back slop. Ignition failure dont seem to want to start right back up so I would be chasing a fuel supply issue.
73azbronco
How's your voltage in the battery under load with motor on?
Have you pulled plugs and checked them and compression to eliminate that as an issue?
Hook a vacuum gauge up and whats it do?
Susan76
Susan76
things checked
Rusty Truck & 73 AZ Bronco
Thanks... Wire harness is aftermarket - other than a bunch of fuses (16) I didn't like it so no name.. no return after you open the package to see what you bought (GM harness)-- new 140 Amp 1 wire alt - 13.8v running. Harness instructions state NO resistor wire in ign feed. Using a 1970 points dist so I don't have to put up with the dummyspark Ford electronic. They are just not dependable where I go.
Vac was at 16-18" initially and steady... using vac guage as mileage tool.. SW dash mounted next to oil pressure & voltmeter.
Plugs - 1-7 barely a tan as only equivalent of 30-40 miles #8 black like choke was stuck on. Plugs I pulled didn't give me any cause for alarm so even though its been 6+ months I would have gone further if a plug showed signs of trouble. I already had it down to intake change and the rad out for cleaning.. would have been very little to pull the timing cover. Didn't see a need for it then.
I just got offered some GT40 heads and another distributor so I may not get to change the carb tonight.
Thanks for all the suggestions.
Susan
bbow
Ozark, Alabama
When to replace timing chain......when your replacing your water pump, shear off a couple of bolts and then break the timing cover trying to get the bolts out. Oh, sorry...that's how I do it.
Susan76
Susan76
thanks for the smile
bbow
Thanks for the smile... too many hrs with FEs.. just pop them apart and change it. No water passage worries, cover comes off the pan... guess I'm lazy..
Susan
broncnaz
While I wont fault you for liking to keep things simple with the ignition. The durspark setup is very reliable. heck you can carry a points dizzy as a back up if needed.
Anyhow Since you've put on a new intake I would suggest you double check the torque on the intake. Ive found they tend to need to be retorqued after a new install and a few heat cycles. You could be running lean due to vacuum leaks or that #8 cylinder may be pulling oil in through the intake.
Susan76
Susan76
torque ok
Broncnaz
Pass frt & #3 pass side maybe 16# barely turned before hitting 18#. Couldn't find the Edelbrock instructions and they are not online but I remember that they recommended a lower torque than Ford's 21-23#. And when I had it apart I #3 (bottom) tapped all the threads and used stainless bolts & washers.
Duraspark - I've had 2 that have literally cost me thousands... I'd rather go (Bronco gods forgive me) with a HEI conversion.. 12v in, tach lead and for a spare the coil & sensor takes up about the space of a stock spare coil. I was pretty sure I had Unilite conversion to put in this dist and then just carry the stock points plate IF I had a problem. Gotta dig through some boxes as I have the 390 it was in. Mustang guys seem to like the pertronix conversion. CJs has it for $75. Simple hookup with just 2 wires to the coil.
Tomorrow night I'll put it back together and swap the carb from a CJ. 735 cfm is little big but should be ok for testing ....
rjrobin2002
Are you a boy named Susan, or are you a female named Susan that knows way more than me on ford engines?
baddad457
A little heat applied to the cover and a gentle amount of torque will prevent that from happening. As will using thread sealer on those four bolts
baddad457
Susan, bump your base timing to 10. If you experience a little ping you can always back off the advance if your canister is adjustable. Otherwise you'll have to back the base down or run a higher grade of fuel..
X 2 on this. It'll be happier at 10-14* BTC
broncnaz
Broncnaz
Well the intake torque was just something else to check. Ive just had it happen a few times. Guess we can rule that out now.
I understand you have a bad taste with the duraspark. Still its one of the more reliable ignitions out there. I wouldnt touch a unilite for anything I've seen so many of them fail its not funny. Much less those cobbled together hei units. lots of people like them but they have a lot of issues as well for the low number that are out there. Pertronix I played around with that idea as well but research showed way more failures than I like to see. But at least you can swap points back in. in the end pertronix is probably a good bet I always liked points but finally decided I needed something better to do than adjust points all the time.;D
Yeah that 735 should at least let you know wether you have a carb issue or not.
Susan76
Susan76
who I am
RJRobin2002
A woman.. does my photo look like a guy???? Although I suspect I would have had a much easier life as a man for the time I was born in. A child of the 60's super stock wars who switched from Max Wedges to Cobra Jets after Tasca brought them out in 68... There are a few of us --Shirley Muldowney grew up 60 miles from me.. she left and got famous... took me 40+ yrs to leave. Never got famous... If you wanted to be around my dad, you learned tools and then the questions why... Dad was VERY sure of what kind of person I should be - I am an INTJ & it shows in all I do or write. We are less than 0.5% of the population so IF you have never met one of us its not surprising. Or just thought that we were a bitch. Now in 2014 its easy to accept that women can be and are very active in all aspects of motorsports.
Cars I had were numerous - buy em, build em & sell em... paid for racing. All brands but 90% big blocks.. if it made me $ fine.
As far as knowing Ford engines, I have liked Fords since my 56 T-Bird (early 60s)... lots of hours with FEs 428s a few with Boss 9.. a dozen or so Shelbys. They were drivers -- try a 67 GT500 in 6" snow cause its your only car and you have to get to work (something had broken on my F250 plow truck). The late 60s & early 70s was all about cubic inches for drags and street. Only small blocks like 72 Bronco circa 1975 when I was into off road racing and a couple of work type F150s in late 80's early 90's that both had Duraspark issues. And But NOTHING since about 1980 as far as really building them.
Now I am chasing my childhood again... 69 stang FB 428CJ 4 spd +++++ that I bought in June of 69, 10+ yr redo with stainless, Global West, QA1s Hooker Schiefer GV and maybe one of my 427 blocks. Haven't pulled the cover off it in a yr+ .. 69 Ranchero GT 351W FMX that has been a 3 yr when I get to it project (health issues). It will probably put either a 390 6V or 428 8V & C6 this summer-- 351 can then go into the Bronco. Found the Bronco almost by accident last yr. Never thought I could afford one at current prices. Bought it with my heart, not mind and have paid the price for that mistake.
Knowledge - my subscription copies of Hot Rod & Car Craft on my shelves go back to 1964... people say I don't look my age. I definitely DO NOT act it (when the body works) but I've probably given you a good idea of it by this point. Oh and a good part of it is from people who WOULD NOT accept me because I am me, so I HAD to learn & do it for myself. I was the only FE builder in my area so I went to people like H&M, Erson, Shelby, KB for information -- think that they felt sorry for me but it worked. I have my own hard copy Ford/Rotunda/Motorcraft parts manuals from the 60s, wiring diagram books, casting #s books. I had torque plates made for FE blocks in 1969 or 70... long before it was common practice. And I KNOW that I do NOT KNOW.
Woman - YES - and very unusual..... I spent more on my garage floor than my living room furniture.... a few photos of my little shop.
Susan76
Susan76
it failed me
Sorry everyone -- first time in 45yrs.. looks like I need to replace the front needle & seat as its pumping right out the bowl vent.. coming off a 428 had to change the transfer line that hasn't been apart since about 1975.... it is the correct numbers carb so it may be dirty but expensive to replace so a little extra cautious about the leaking fuel.... photo of where I borrowed it from and on the Bronco.. 428 brakes hooked to manifold so no vacuum for brakes.
