when to replace timing chain?
Susan76
Susan76
trying to figure it out
Broncnaz -- close look at the gauge I'd say it was at 195-200 on a 180 stat.
& DirtDonk -- Ford racing always told us front edge of the fan should be 1" into the shroud if possible to get the max fan pull of air across the radiator... BUT that was 1970 & I have really NO idea what the correct fan should be. Anyone know what diameter its supposed to be???... I am using a Ford flex - looks the same as my CJ fan. I could probably do 1 -1 1/4" spacer.
73azbronco -- looking for help, suggestions, a sounding board to see if I AM screwing up, tapping into a greater knowledge base as my last Bronco was a ??1972 in 1975 so it was fairly new in comparison the the 35+ yrs on this one. Didn't do a lot to that one - holley 350 2bbl, air filter, 3" rancho, flares & BFG mudders. In those days besides my speed shop doing customer vehicles, 98% of my spare time was spent on my race Blazers as I was under contract with a tyre company. I ran 17x40x15s in 1974-78....
Don't know what you mean by "Sierra Vista"...
I KNOW that I do NOT know. And the older I get the less I know....
Susan
WheelHorse
One time when I wish I had O2 sensors available... or portable so I could plug in the tailpipes and go for a run....
I run a MTX-L in my Bronco. This way I always know what's going on with the AFR.
When I had first installed mine, I found out she was very lean like 17-ish going down the highway and that was causing some of my heating up issues.
Once I rejetted, she ran cooler at low 14's AFR.
broncnaz
Id probably swap the tstat out for a 195. And if you have a aux pusher fan installed remove it. Actually 195 -200 is not to bad. Broncos have a fairly small cooling system. I wouldnt be to concerned until you start running 240 or more. Of course its always better to be able to run closer to the t stats rating.
Susan76
Susan76
gauges
Wheelhorse
I looked at the Innovate LM-2 hand held dual inpt thinking about my other two builds --- the two sensor one at about $500....
Then thought now nice it might be to have a permanent mounted one. Probably going to order http://www.glowshiftdirect.com/black-face-wideband-air-fuel-gauge.aspx and their matching guages to replace my SW. Just like the look of all the same. http://www.glowshiftdirect.com/black-7-color-water-temperature-gauge.aspx They will fit in the SW mounts. I'd replace my vacuum gauge with a water temp in the top hose. and then mount the O2 more heads up for constant easy reading -- mileage.
only problem is I'll need to get someone to weld in the O2 bung. never understood why no one ever designed a clamp on bung. -
broncnaz
Most likely the reason no one designed a clamp on type bung is the O2 should be sealed from outside air or you'll get false readings. Hard to garruntee a air tight seal with a clamp.
WheelHorse
If memory serves me correctly, I went with the MTX-L because it was one of the most accurate a DIY'r could purchase. There's some articles floating around out there about the accuracy of these smaller gauges; be sure to do some homework before pulling the trigger.
Susan76
Susan76
bunch of little things
Sorry guys, been a while.... I have a medical condition that popped up & get my pacemaker replaced unexpectedly tomorrow......
A BIG DUH - there is a 3/4" fan spacer... just didn't realize it as it always stayed on the fan when I took it off. --- Hooked up the heater & added a qt of super cool... found out my low oil pressure safety switch was not working so mech pump had to pull through the elec most of the time unless I was manually pushing the over ride switch.
Added a variable rate fuel pressure regulator. Changed my 1970s nostalgia tach from one of my race trucks that didn't work so I can get some real sense of RPMs now. I also backed the secondary idle screw out 1 1/4 turns so the idle is back to 700 in neutral.. 625 drive. BUT idle adjusted off the primary now. I also bumped the timing to 12*.. Pointer is still steady at all rpms so the timing chain was never the issue. Bad distributor - still haven't taken it back to Auto Zone. Pulled plugs 1-3 & 5-7. Really don't have anything to say other than they are all clean and need miles to really see a pattern. Must be the lack of lead in gas doesn't show pattern as quickly as it used to. Didn't drive it far enough this AM to really see and differences. Hope to this evening.
Wheelhorse.. Still debating on the hand held vs perm installation. Isn't the one you have a hard cable from the gauge to the sensor? Like a mech water temp? Wonder how accurate a gauge I really need for the Bronco vs my 427s and 428s that may see 7,000 and full throttle 1/4s.
Thanks everyone for your responses.
Susan
Susan76
Susan76
mileage sucks
Finally took it for long run 230 or so miles. 98% interstate. Ran well. 3,000 rpm @ 65 mph (GPS) Temp up to 210* but held there and any slowing to 55 (construction) dropped to about 190* Pulling 10-11" vacuum most of the time. BUT net on the one tank - not much to base opinion & I tried to fill the same way -- mileage was 8.8 mpg.. far below what I was expecting.
So change gear to 3.54 (I may have a complete 3rd on the shelf) & try it. No gear in the front as I had chest pain when I started to do it... Thing is I won't be able to do almost anything for a 4-6 weeks (can't even look at the plugs for 2 weeks) with the surgery I had last Friday...
So buy the O2 gauge & see what is happening.
Comments?
Susan
broncnaz
I think your vacuum is low. Probably should be pulling more you may need to play with the timing some. Amybe just the advance rate. Before swapping gears as higher gears will only make the vacuum lower. You should be able to pull 12 mpg or higher when properly tuned.
WheelHorse
Susan,
It's just a cable.
Here's a thread I had started last year regarding timing strategies and AFR using a wideband. I buck the trend with recurving and running full manifold vac and playing with powervalves.
Tuning a Motorcraft 2150 via wideband
This was completely stock everything with the only exception being a single glass pack. Cam chain had 8 degrees of slop and the exhaust port was so restricted we'd have to call it a severe case of emphysema. This year she'll be getting a performer cam and cloyes true roller timing set, new heads (mildly ported e7's), and a mildly ported 2bbl intake to keep her stock appearing. I'll revise my thread once I get it all back together and redialed in.
Figured it would give you something to read while you're recovering. ;)
Susan76
Susan76
wow!
WheelHorse
Now I am really feeling OLD. Almost want to double stack pacemakers for a boost after that excellent read. I am definitely stuck in the 60s tuning mindset and need to update my thinking and knowledge.
One thing I didn't see was rpm references and a gear ratio/tyre size as a loading factor on the engine on your Bronco.
I know I made a big mistake in calc of my intended RPM last yr as I was anticipating what combination to use. Don't know where I screwed up but I was under the mindset of 2,300-2,400 rpm instead of 2,800 - 2,900 that I am seeing at actual cruising speeds.
You have a permanent installation single exhaust which I had intended on going to but with my rpms so high I need to fins what tube size for a single or stick with the existing duals (no balance tube). And the question of sensor location - right or left? And do you find the permanent installation useful as to changing tuning for winter or is it now become pretty gauge that drives a more gentile right foot? -- hence am I better with the portable that I can use on my 2 other builds?
Susan76
Susan76
rpm
WheelHorse
For MY use of this Bronco -- high rpm -- highway 3,000 -- off road low range 1st gear 3,000
I thought base 302 cam had peak torque about 2,600 rpm so in theory best fuel mileage should occur a bit under peak torque. Hence my 2,400 rpm goal for highway.
73azbronco
Susan, first, get well, to hot this time to be out in the heat. I recommend if you can swing it, call up Loppers in Phoenix and see what it would take to dyno tune the rig. The expense of getting tuners and sensors is in my opinion outweighed by the shear simplicity of dropping off the rig and getting it back fixed, for about the same price in money and time. I've done both, and now will take it in to get it done.
You're also going to have to decide what you want, hiway or offroad? You can hit both, but both suffer optimum performance. Hoenstly? I recommend slowing down and hitting the offroad side, and slower on the freeway to preserve some fuel mileage.
