blubuckaroo
Grease Monkey
I've got 1 set of National 11 leaf rear springs. It already hard a bit of rake to it, but then I added a 6 degree tapered shim to correct the driveline angle.
Now the rake is quite a bit worse.
I'm thinking of removing a leaf or two from the rear. I hope to lower and soften the rear a bit. I'm also hoping that, with it a bit lower, I'll also be able to eliminate the tapered shim.
Question is, which leaf or leaves should I pull out?
