Which setup: 351/AOD or Explorer/AODe
adamwhatley
Hiya, I'm trying to figure out the next step for a Bronco I'm building.
Option #1: I have a 97 Ford Explorer, which is EFI mated to an AODe transmission. I'd have to finesse the harness, add a trans to tranfer case adapter, add HP fuel, and mount the whole setup to get it going.
or
Option #2: I have a 351 Winsor, not EFI, mated to an AOD mated to a Dana 20. To get this going, I'd have to add the adapter from trans to transfer case and buy a carburetor.
Anyone with experience of one over the other or disappointment with one over the other? This will be my daily driver, on road truck (no wheeling, etc).
904Bronco
San Martin, CA
An Explorer has a 4R70W, which is the brilliant brother of the AOD and AODe.
If it is a later 97 build, it could have all the desirable upgrades done. IF it is AWD then you do not have to go into it to adapt it to the D20.
I recommend going EFI, you already have the donor... EFI Guy can rework the harness and reflash the ECU..
See you at the Round up... I will be bringing the D20 that you asked to buy... You have my Ph# Doug
Option 1
EFI is great. Much better transmission.
As much as I love the 351, the 4R70W transmission is so much better over the AOD I would loose the displacement to gain the better transmission.
Depending on the 351, the Explorer could easily have more torque and power.
