I heard all softball canceled due to weather, during OCBR.....
I wish..........There's a chance we might be free that weekend.......Not a good chance but a chance......
Tim
Guys feel free to chime in. I'm not easily offended, thinking out loud here based on what I've read recently and may help Tim to hear other opinions.My setup will end up being
351W GT40 top end, stock bottom end (cam to be determined)
ZF 5 speed
4.11 gears
17x8.5 Method Wheels 285x75x17 Nitto Grappler MT Tires 33's
Right now I have 32's and stock 3 speed, 4.11's
Tim
Great graph. I was curious about the 308 also when I was looking. On the 35- 413 cam yes it is a no starter as a roller retrofit but it appears if you advance the 35-349 4 degrees you end up with the 35-413 power band. I may still try this to bring the torque in sooner like an explorer cam but have top end still above 5k. I have 9.5:1 CR ratio so the lower dynamic cylinder pressure from the advance shouldn't hurt much.
How much is the DTD software?
Sent from my SM-G900V using Tapatalk
Thanks for that. Looks like the LSA has an impact on top end but would make bottom end suffer for the 413 grind. I was too focused on the duration lift and open close events. The grind is probably advanced to compensate for the increased LSA over the 349 cam
So in the case of poorly matched gearing in Timmys 351 and my 347 you would expect little to no benefit advancing the 349 cam to slide powerband down? No significant increase in Low rpm torque with the loss of top end?
I thought it may be worth a shot since it only costs a timing gasket set.
