Same here. My 2100 would not run well in Colorado and did not run at all over 12K feet. EFI solved that completely. Sure it loses power at altitude, but still runs! I'm sure bmc69 was talking about off camber and up and down hill performance which EFI solves as well, but my main issue was operating at high altitudes in Colorado.
Also, I like the fact that there is no warm up time. Start it, let the high idle drop (only a few seconds) and drive away. I hate working with and adjusting a choke.
Is it worth $1K - $2K for you do do it? From your description of how you use your Bronco, I don't think so.
I'll be the turd in the punch bowl here. Apparently a lot of people on this forum do not know how to tune a carb, and this post exemplifies the sort of complaints that are levied against carburetors all the time that are really tuning issues. EFI runs like shit too if your tuning is jacked up %)
As long as you run a correctly installed low pressure fuel pump with an appropriate pressure regulator (to avoid vapor lock), a properly tuned carb will run just fine even on the highest passes in Colorado. My '75 had a 2100 and my '84 Bronco II has a 2100, and both run pretty much like fuel injection.
I have been up and down just about all the passes in the San Juans no problems (once I ditched the mechanical fuel pumps). I have gone from ~3,700' to nearly 13,000' without having to fiddle with the carb at all and suffered no significant ill effects. My rig fires up and idles no problem from as low as -5ºF to 110ºF.
As far as off road performance goes, the 2100 runs great. I will end up upside-down before the 2100 stalls or floods. Granted, many carbs don't do very well off road (Edelbrock in particular), but 2100s are one of the best off road carbs out there.
As far as carb maintenance goes, I haven't really had to mess with my 2100s at all after getting the initial tune dialed in. Carb tuning scares a lot of people, but it really isn't that bad if you understand what you are doing and use the proper settings. Way too many people have no idea what the hell they are doing and just start making adjustments and everything ends up out of whack
If your carbureted vehicle sits for long periods of time, be sure to only use 100% unleaded gasoline and/or use fuel stabilizer that specifically treats the ethanol in the fuel. I have had my rig sitting for months sometimes even without 100% unleaded fuel or fuel stabilizer and it fires right up though.
Sure, fuel economy will be marginally better with EFI, and as good as my carbs are, drive-ability will improve as well. Personally, I wouldn't bother with the expense of fuel injection over a good 2100 unless you are desert racing or doing some really extreme rock crawling. I really like the clean look of a carburetor as well and feel fuel injection looks out of place on a vintage ride.
I am not an EFI hater, and it is a nice upgrade, I just hate to see people bash so much on carburetors when it is usually tuning problems that are to blame. For street driving, and even extensive trail usage, a 2100 will serve you well, so in my opinion, skipping the EFI is a good place to save some serious coin.
