Wild Horse adjustable track bar bolt sizes ??
73azbronco
Just looking at new to me WH adjustable track bar, seems the bolt holes are not stock.
The frame side track bar size is 3/4, and my stock frame side shows about 1/2 maybe 5/8ths?
The axle side track bar uses 1 inch bolt and my oem size, verified with another makers bolt, is 3/4.
What am I missing? I can't really see installing a 1 inch bolt at the axle side. Or redrilling frame side to 3/4.
1969miller
Elk Grove
The hardware for the WH track bar is the same as stock. Here are some photos (aftermarket frame in these photos)
Axle side is 3/4, and frame side is either 5/8 or 9/16 depending on the year. 76-77 uses the 9/16 and 66-75 uses the 5/8.
1969miller
Elk Grove
I see now that you got a "brand used" track bar, does it have metal sleeves inside the bushings? If not it could explain the size difference. Have any photos?
jamesroney
Fremont, CA
Last time I checked, I used a 13/16 wrench and a 7/8 wrench on my 9/16 diameter upper track bar bolt. It’s a 1970. Factory frame bracket, factory track bar.
I can confirm tomorrow, but I’m about 95% sure.
