rojo23
I am in the process of installing the front disc conversion from wild horse on my 75. I can get the spindle and caliber bracket installed and torqued to 40 ft lbs but then I cannot turn my axle stubs. It feels like once everything is torqued down the axle is binding on something. It appears the axle stub is not centered in the spindle. Should I be shimming they spindle to the knuckle? I started on the pass side and the. Tried the drivers side and same issue on both sides. I am sure it is operator error but cannot figure out the issue. Thanks
