I think we got you covered Bob, but to reiterate (in case someone can use this for reference when it happens to them too!), the shock lengths are as follows.
Rear shocks for a 2.5" lift using stock mounts:
Approx. length is 22.80" extended and 13.94" compressed.
Front shocks for 2.5" lift using our Extreme hoops:
#2 position (just behind coil spring) is 26.69" and 15.84" respectively.
#3 position (rearmost) is 24.40" and 14.79"
All measurements are taken eye-to-eye, since he's not utilizing his stock front mounts and does not have an early '66 model which uses a different rear mount.
Since Bob is sourcing his own shocks, all lengths are going to be approximate, as they correspond to our Extreme shocks. But they're close enough for Government work. As we used to say...
