I thought there was a tech article on swapping the 351W. Couldn't find it.
Simple answer, it swaps in fairly easy. Motor mounts, transmission just bolt up. I know there are lists out there somewhere, but the short of it is there are a few things that's don't interchange off the old 302 onto the 351.
Oil pan is special to the 351, the '88 should work fine after putting a dent in it for the front diff. Usually it is just consider self clearancing after the first bottoming out and then all is good
Intake is wider, special for the 351. The EFI intake is too tall. Not sure if you were planning on EFI or a carb. Probably best to take this tangent to another thread, especially with stroker plans.
Distributor is unique to 351W. The bore is slightly different and the biggy is the oil pump driveshaft is 1/16" bigger on the 351
If you run the Bronco accessory drive (timing chain, balancer, pulleys, etc.) then a could simple and cheap adaptor spacers will keep everything on the front of the engne stock Bronco. Other choices exist as well.
IF the 302 cooling system is in good shape, it will usually do OK even with the 351.
Exhaust pattern on the heads is the same, but the ports are a little taller and wider. Minor exhaust modifications are usually (but not always) needed. Some 302 headers will work on 351 others won't.
Hood clearance is tight. Low profile intakes and air filter have been known to fit under the stock hood. What would be needed to feed a stroker will require some help. Tall hood and/or body lift.
Body lift also helps with the throttle linkage to valve cover clearance but is not needed. Venders do offer speciality linkage or cable conversions.
That is most of it.
