The Wilwood MC4 parking brake calipers are relatively easy to adapt to just about anything so long as the rotor thickness aligns with the calipers you choose, as they have a narrow (.81") and wide-body (1.10") version, both in mechanical and electronic variants. I have a customer running a set of these on his G-body (78-88 GM mid-size) with pretty good results, although he said that it doesn't take much of a slope for them to slip, so I question their maximum holding torque. His are mechanical, so we're looking at his cable setup and actuator to make sure that he's setting them as hard as they should be set, but clearly the electronic units wouldn't have any such concerns, though you add in the wiring harness and servo controller. Packaging sure is relatively easy though.
