Wiper park position
bteutsch
Can anyone tell me the propper parked position of a stock 71.5 wiper motor? It's mounted in the stock location. (No drop bracket) It's been a couple of years since I had it together, had installed the delay wiper switch and box before I took it apart for a frame off. Everything was working when I took it off, now two years later I have the motor mounted and hooked up and the wiper linkage connected. The motor runs slow in the delay position, switches off in the off position, slow in the low position and then fast in the hi position. Motor doesn't delay and doesn't park. It just stops where you turn it off. My best guess is when sitting in the seats the arm on the motor should be in the 9 o'clock position? Is that right? Unless I hooked something up wrong my next job is diagnosing this wiper park issue. Went to the junk yard after reading some of the other posts on wipers and pulled two complete wiper delay setups, thinking it may be the governor box or delay switch, but they all three ran the same. So either they are all bad or something is wrong in the motor. 99% sure it's the original wiper motor.
JohnJohn
Richmond
I have had your problem twice with two different broncos. I bet the park issue is caused by dirt stuck in between the two contact points inside the motor. I was able to just slightly pull open the electric motor and shoot break cleaner in to fix the last motor that would not park. On my first one I pulled the motor apart and cleaned it. It just makes putting it back together harder because you need to hold the brushes back with 3 hands while putting it back together.
Check out these threads:
http://www.classicbroncos.com/forums/showthread.php?t=162048
http://www.classicbroncos.com/forums/showthread.php?t=164222
bteutsch
bteutsch
I have the factory harness and its possible I could have plugged the pigtail that comes from the motor near drivers side as it drops through the windshield frame there were two of these two wire flat trailer style connectors I thought I matched the colors but who knows. It was pretty cramped there behind the speedo cluster. It was all working two years ago when I took it apart. The little black box that is the wiper governor did a couple of times make a growling or buzzing noise so I guessed it may be bad. I pulled a couple from the junkyard and hooked them up with their switches and it worked the same. No delay, no park. I'll make this my project today.
bteutsch
bteutsch
Okay so I did some testing so far this is what I came up with. I had my buddy bring his 77 model over, his wipers do park with the factory switch, so I took all three delay wiper switch setups that I have, all work perfectly on his, this at least tells me they work. Now to figure out this motor on mine, is it hooked up wrong or is the park contact dirty or bad?
bteutsch
bteutsch
Sounds like I'm tearing down the motor then at least enough to clean the switch.
Viperwolf1
electron whisperer
Got a voltmeter? Measure voltage at the plug near the motor.
bteutsch
bteutsch
With wiper switch set to off and key on I get 12.33volts on red wire. All others are 0volts.
With wiper switch set to delay and key on I get 12.33volts on red 11.94 on white all others 0volts
With wiper switch on low and key on I get 12.33volts on red 11.94 on white all others 0volts
With wiper switch on high and key on I get 12.33volts on red 11.94-96 on white 12.32volts on blue an 0volts on black
All tested at plug near motor with motor unplugged..
bteutsch
bteutsch
Okay so now I checked at the plug with motor connected and motor running by connecting the plug an backing it out just enough to probe the connections.
With key on and wiper switch on delay red wire has 11.90volts blue is 7.23 volts white is 11.07volts and black reads .11volts
Results were basically the same with wiper switch set to low
With wiper switch set to high red 11.80volts blue 11.5volts white 16.20 and black .69-.73volts
bteutsch
bteutsch
Okay so I took the motor down and took out the two bolts, I eased the case back about 1/4 inch, I can see the brushes and possibly the park switch contacts, I sprayed them off with brake cleaner an am letting it dry out. Is there anything I need to try and bend to make a better connection with the park switch? And after spraying brake cleaner do I need. To lube anything before I put it back together.
JohnJohn
Richmond
On the two motors I fixed it was just dust preventing the contact from connecting. I would put it in and give it a try. If it does not work try pulling it fully apart and inspecting it.
I just posted this photo in another thread today but this is the contact area that makes the connection and forces the park. It moves from a cam that turns with the main shaft of the motor.
This is not my photo so I hope the owner does not mind me posting it but I circled the contact area in red.
bteutsch
bteutsch
Success, I went ahead and pulled the rest of the motor apart, found a nice sized dead spider and some web in the contacts for the park switch. I had fun with those brushes for a minute and then I grabbed some of my sons rubber bands for his Braces. Took two on each brush to hold them in place, carefully slid the motor together and grabbed the rubber bands with a hook tool and carefully cut them and pulled them out one at a time. Bolted it back together and done. As soon as I hooked the motor up it went to its park position. Delay is working as well. Thanks everyone for all of your help!!!!
