bteutsch
- Joined
- Jan 11, 2009
- Messages
- 875
Can anyone tell me the propper parked position of a stock 71.5 wiper motor? It's mounted in the stock location. (No drop bracket) It's been a couple of years since I had it together, had installed the delay wiper switch and box before I took it apart for a frame off. Everything was working when I took it off, now two years later I have the motor mounted and hooked up and the wiper linkage connected. The motor runs slow in the delay position, switches off in the off position, slow in the low position and then fast in the hi position. Motor doesn't delay and doesn't park. It just stops where you turn it off. My best guess is when sitting in the seats the arm on the motor should be in the 9 o'clock position? Is that right? Unless I hooked something up wrong my next job is diagnosing this wiper park issue. Went to the junk yard after reading some of the other posts on wipers and pulled two complete wiper delay setups, thinking it may be the governor box or delay switch, but they all three ran the same. So either they are all bad or something is wrong in the motor. 99% sure it's the original wiper motor.
