wire connectors
Past_Miner
Looks like you beat me to the answer while I was typing at my blazing 10 words per minute.
ASE-73
Seattle, WA
dingo8 said:
on a related note:
does anyone know the maximum wire size that the weatherpacks can handle? can they handle 12 GA? 10 GA? 8?
Also, what's the highest amperage that each weatherpack terminal can handle?
[edit]
If you're gonna use these in higher amp applications (like offroad lights, etc) keep this in mind. They may not be able to handle the current or wire size you desire...
Assuming Offroad Lights are running 100 watt bulbs ... (100 watts /10 volts) = 10 Amps (worst case current draw) ... this is well under the WeatherPack continuous rating.
dingo8
Luzerne County, PA
the lights was just an example.
however, you may, at some point, be powering both lights on the same wire since the relay has only one 87 terminal.
some folks might run both lamp wires to a single 1/4" quick connect for the 87 terminal. some folks might run a single wire out of the 87 terminal and then split power (as KC Kilites shows in a diagram here). you're also going to have only one wire coming from the vehicle's power to the relay's 30 terminal this will carry amperage for both lights.
all in all, it doesn't change the fact that the weatherpacks can only handle 12AWG @ 19 Amps. it's just adding another ingredient into the soup that i like to call "designing an electrical circuit", so the user needs to keep this all in mind...
flint_knapper
BRONCO GOD
Harvest, AL
it would be better to get a relay that has 2 "87" terminals and
run a seperate 12 GA. wire to each light. ;)
ASE-73
Seattle, WA
Exactly ;) To install relays and not go single wire undermines maximizing the benefit of relay actuated lighting.
dingo8
Luzerne County, PA
Gummi Bear
Good to see all y'all going in the right direction. The NEC requires me to oversize all conductors and overcurrent protection by 25% in a standard A/C voltage system, and I carry the same mentality over to my Bronco.
This is the simple explanation:
Example - if my headlights draw a total of 20A, I will use wire and connectors, and overcurrent protection (fuse) that is rated at, but not to exceed 25A.
