If everything is clean and prepped a solder connection is far superior to a crimp. You are fusing the two pieces together which takes advantage of the entire surface area of both pieces versus a crimp that wedges a portion of the connector to a portion of your conductor and can leave area open for corrosion which can lead to a high resistive connection. Don't get me wrong, crimps are fine and used all the time but if you are asking what is best, it would be a soldered joint. If you are using solder connectors then there is no need to crimp prior to soldering, just solder them together. Greybar in Goleta sells a lot of the sta-kon connectors as well as the Thomas and Betts crimpers which are my personal favorites. As others have stated, the weather pack connectors would probably be the way to go for what you are doing.
