Wire harness and alternator
jllj69
I recently bought a wire harness from Dennis Carpenter and changed out my alternator (69 ford bronco). I bought a 55 amp based on Advances recommendation but then realized the wire harness said it does not support a 55 amp. What should I do from here? I honestly didn't realize and of this until I was installing everything and the alternator wire plug would not fit in the harnesses plug. They both have two silver plugs and one black insert. Would buying a 70-80 amp alternator come with wiring that would match?
What did you see that says you can't use the 55a alternator? My thinking is that since Ford did not change the harness whether you had a 35 or a 55 amp alternator, it does not seem like it's anything more than the legal department saying "CYA" just in case.
Since 55a was an option for Broncos (at least later ones) then as long as it connects correctly to your original harness, you should be good.
The harness connections did change over the years, so there is that. But if your new harness is correct for your year, I would think you're good to go unless it physically won't fit the new alternator?
That's odd. So this is specifically for a '69? Maybe Ford did make changes that I was not aware of. Apparently so!
But you can still make it work if that's what you want. If the wires match, create your own connections if you're up to that in the wiring department.
Can you post up some pics? It would be good to see just what it is you're dealing with. At least post up a link to the Dennis Carpenter part on their website.
No, never that I'm aware of. They're not even the same alternator in fact. Yours is a "small case 1G" while the 70 to 105 amp models are "large case 1G" alternators. It's what I have on mine, but you need to change the connections at the alternator.
No replacement 1G's come with their own harness that I've ever seen. Does not mean they don't exist, and I'm sure someone has thought about it, but since most companies don't like to be seen encouraging us to swap in stuff that did not come from the factory, it's very unlikely until you get into small custom aftermarket companies.
But let's see some pics of what you have.
Oh, and welcome from here too!
By the way, although you can't post images directly to the discussion until you're a "contributor" for 12bucks a year, you can post them up into your "garage" and 'gallery" functions up top. Or you can e-mail them to one of us with the contributor status under their username. Like me in fact! So you can send them to paulb@wildhorses4x4.com and I can post them into this thread for you.
Just wondering if during some other changes in other areas, this was about the time Ford was changing from the early 1G to the later 1G alternator and that's why the harness does not fit.
I know there were different harnesses during different years, but have not always followed just when they were made. Things like different master cylinders, different windshield wipers, different light setups, etc. And '70 was about when they were planning to make big changes to the overall chassis harness (did not happen until '71 though) so maybe it's all part of that.
Easier to adapt the alternator end than it is to adapt the main connectors, but nothing is impossible!
paul
J
jllj69
Wow! Thank you all for the replies and welcomes. After chasing down everything today it seems they used a 60 AMP (or previous owner switched to it) based on if it had an A/C or not. Does that sound right? I swapped my 55 for a 60 and realized that I just needed to splice out one of the wires (middle thickest) on the two 3 pole connectiors to make it work. I will be installing those tomorrow so please let me know if that sounds way off. Here is a link to the part https://www.dennis-carpenter.com/trucks/electrical/wiring/c9tz-14290-a-1969-dash-to-headlamp-wiring
The plug in the top left of the picture connects to the alternator (3 pole connector)
Wow, an entire early model firewall-to-engine compartment harness! That's pretty nice.
And about time too, since these things are so valuable anymore I'm surprised that there have not been wiring companies falling all over themselves to re-create the stock harnesses for at least some years.
That one's right from the two pesky (and deterioration-prone) rectangular firewall connectors, out to everywhere else.
But it looks to me like the voltage regulator connector has the same mistake made to it that so many other harnesses have. It's wired wrong! (edit: correction, I was looking at it wrong)
Or at least it looks like it. Can you run down the wire colors and positions of the 3, or 4 wires on the regulator connector? In the picture it's gray with what looks to be 4 (or 5 if you count the two Yellows) wires starting with the Orange one.
If it's correct then you're good to go. If not, we can run down how to re-pin it for correct operation in a Bronco.
No A/C ever as an option on Early Broncos. They were all dealer and aftermarket installations. Companies like ARA and a few others used to offer an under-dash module and add-on brackets and such. Never done at the factory until the big Bronco came out in '78.
Back when your Bronco was new, a 60a alternator in the small size was not even an option. The aftermarket rebuilders, then the new replacement companies (sometimes they were one and the same) started upscaling the output. I think the normal limit nowadays is 65a until you get to custom high dollar builds, and 70 through 105 or so for the large case alternators (also never offered on the early Bronco).
So yes, a PO may have simply replaced the alternator and the store offered a slightly up-rated model. Might not even have had the original outputs available any longer. I have not seen a 35 or 45 amp alternator in a local store in a long time. They're all 55 or 60 or 65 at least back when I was checking.
But here again, the backside connections on the alternator probably did not change (or change much) between a 50, 55, 60 or 65 amp alternator. These are generally all the same case design, but with beefed up internals to get the higher output.
Definitely take pics of the back of your alternator and the new wiring harness when you get the chance. Especially at the regulator connector.
Have fun! And good luck with the install.
paul
Correction. I looked at their image again and it does look like they have the regulator wired correctly with only the 3 out of 4 positions filled.
Good for them. Would have been a lot of trouble and expense to go through to make it wrong!
paul
J
jllj69
So.. I just finished the breaks and fired it up for the first time. It was idling a little high but can play with the carberator a bit. The big surprise when I lifted the hood was that the ground wire on the alternator had completely touched through the lining all the way to the plug it connects with the new harness. Luckily it stopped there. Any ideas what could cause this?
It would be the black wire with a pink or purplish line. It connects to one of the smaller 3 nuts on the back of the alternator speared from the main two that have a rubber cover.
Let’s see a picture please if you can.
How did you wire it up so that everything worked with your alternator?
Don’t know of any black with purple or pink wires wire on an old-school alternator.
On modern 3G‘s the main charge wire is black with orange. But it would also be very big, and would not be mistaken for anything else.
Did you ever post the pictures of the new harness compared to the old? Curious to see it.
The most basic thing I can think of that would cause your wire to do that is if you don’t have a good engine ground or there was +12 V to that wire.
Double check your main engine ground to make sure it’s tight.
Rustytruck
our stock alternator all the wires bolt on to the alternator. the second generation alternators added plug in connection and ford had problems with that connection and the alternators started having electrical fires from the connections when they got loose and melted the plastic connector then ford completely redesigned the alternator to the 3/4-G design. which solved the fire problems. if I was selling wire harnesses I would not support a faulty design either and having my wire harness catch on fire and opening the door to legal issues.
look up ford alternator fire on the Google.
