I recently bought a wire harness from Dennis Carpenter and changed out my alternator (69 ford bronco). I bought a 55 amp based on Advances recommendation but then realized the wire harness said it does not support a 55 amp.
What did you see that says you can't use the 55a alternator? My thinking is that since Ford did not change the harness whether you had a 35 or a 55 amp alternator, it does not seem like it's anything more than the legal department saying "CYA" just in case.
Since 55a was an option for Broncos (at least later ones) then as long as it connects correctly to your original harness, you should be good.
The harness connections did change over the years, so there is that. But if your new harness is correct for your year, I would think you're good to go unless it physically won't fit the new alternator?
I honestly didn't realize and of this until I was installing everything and the alternator wire plug would not fit in the harnesses plug. They both have two silver plugs and one black insert.
That's odd. So this is specifically for a '69? Maybe Ford did make changes that I was not aware of. Apparently so!
But you can still make it work if that's what you want. If the wires match, create your own connections if you're up to that in the wiring department.
Can you post up some pics? It would be good to see just what it is you're dealing with. At least post up a link to the Dennis Carpenter part on their website.
Would buying a 70-80 amp alternator come with wiring that would match?
No, never that I'm aware of. They're not even the same alternator in fact. Yours is a "small case 1G" while the 70 to 105 amp models are "large case 1G" alternators. It's what I have on mine, but you need to change the connections at the alternator.
No replacement 1G's come with their own harness that I've ever seen. Does not mean they don't exist, and I'm sure someone has thought about it, but since most companies don't like to be seen encouraging us to swap in stuff that did not come from the factory, it's very unlikely until you get into small custom aftermarket companies.
But let's see some pics of what you have.
Oh, and welcome from here too!
By the way, although you can't post images directly to the discussion until you're a "contributor" for 12bucks a year, you can post them up into your "garage" and 'gallery" functions up top. Or you can e-mail them to one of us with the contributor status under their username. Like me in fact! So you can send them to
paulb@wildhorses4x4.com and I can post them into this thread for you.
