Snowblind
Hopefully somebody has seen this before. Turned off my truck ('77), had key in hand and heard this slight rumble and realized my truck was still running. Put the key back in and turned it off again without a change, went thru the gears and nothing would turn this thing off. Decided to pull the coil wire and undo the battery. Connect the coil and battery up again and it starts no problem just doesn't want to stop running.
I'm thinking the ignition switch but wanted to check here first in case there's a different solution.
Thanks,
SB
Thanks,
SB
