I get and understand what has been said.
but heres the thing. I have merely $400 into this bronco.. so buying a new tub or paying to fix it would run me the same or less than buying a new one. The frame is NOT BENT. The engine IS FINE. I 'need' to replace the front clip and driver door, twisted rear quarters are merely visual for now. And if the same couldn't be straightened they could be replaced later.
I have a daily driver.
I would have sold the bronco by now had that been an option and was offered $2000 as sits.
It hit weird which makes it look more torn up than it is. When it hit the trees it tilted up against them, thus the smashed top. In doing so it took any pressure onto the top and left front fender-door-tire. That's why the frame is fine. NO its not a wise thing to rebuild, NO it wont be cheap.
But i'm going to do it. simply isn't much of an option.
so heres my question.
What decent parts do i need to rebuild to fix up my front and dash for now. Lets start with that.
swap ins from some trucks? cut up chop it? Welding and fabrication are not an issue at all. Have a commercial (old...) shop and machine shop in my tool belt.
First order of business will be designing and building a roll cage....
I get all the fatherly wisdom and apologize for evoking it. Yes you're all right. I have had the experience myself too now. I was belted in but my saving grace was the amount of pressure I put through my arms into that steering wheel. I broke the steering wheel using my arms as shock absorbers and punched out the driver side window which is where i kept my head to keep from being crushed.
Luck had nothing to do with it, im blessed and don't know how so much happened so fast.
Is any of this bronco addiction really worth it?
the frame is most likely bent,
after an impact like that
dude, you need EVERY part
because every part is smashed,
if you dont even know what parts you need to repair it, dont bother attempting to repair it.
and why waste time and money designing a roll cage?
there are dozens of well designed cages available from lots of vendors.
they have already done all the design and testing and bending, and some of em even do the welding.
lots of people on here have offered you good solid advice,
because YOU ASKED FOR IT !
so listen to em.
the body on your truck is scrap metal, its worth 7 cents a pound at the crusher, if you got offered 2 grand for your truck you should have taken the guys arm off grabbing the cash. there is no way its worth half that.
buy another truck and start over.
you are absolutly wasting your time doing anything other than getting another decent truck and starting over,
you may have a few unsmashed parts on yours, sell em and use it to fund the next one.
get a cage and be careful driving, if its below freezing, there may be ice on the road, a good driver always has a plan to deal with the unexpected,
Ive been thru the same thing,
my first car when I was 15 was a 66 Thunderbird
it got rolled, sideways and forward end over end
I salvaged the engine and interior.
bought another nice body with a blown engine and ratty interior and swapped em over.
