- Jun 4, 2002
- 37,063
I just advance it a little at a time until it knocks running full throttle up a hill
Then back off just a little
I have a 90 mustang motor with the mustang efi. And it's currently at 37 degrees
If you go a step further and start backing the timing off until it looses a little power, then go back to the last setting that was good power. That is a better setting. Gives a better safety cushion for a tank of bad gas or odd weather conditions. Less timing at idle helps emissions and idle stability. Makes the engine less sensitive to load.
