As I start to move forward (regardless of in gear or not), I get a knocking. My double cardan seems really loose. I get under the truck and I can move it side to side a good inch or two.
Pretty much any u-joint setup, double or single cardan type, should be free of any visible play whatsoever? So that one that moves like yours is toast. Whether it moves 2 inches, or 2-tenths of an inch, it's toast.
Actually, there
IS some play, but you would normally not be able to feel it by hand. You'd have to measure it with dial-indicators and such.
Where exactly is it moving? With that much, it sounds like you might have not only bad joints, but the centering yoke and ball could be bad as well.
I was thinking I could just take that joint out and take the driveshaft all the way up to the transfer case if the splines are long enough. Any advice or ideas?
Do you mean take the special double-cardan setup out and use just a single joint at each end? If so, I wouldn't. You "can" of course, if you have a custom shaft built or yours lengthened, but by the time you do that, you might as well have paid for the new CV stuff and just fixed what you have.
Assuming it's still fixable that is. After all, that
IS a bunch of movement.
Also my driveshaft I can get a half rotation in before it locks(this is off and just sitting there). Is this normal?
So what's moving? Your driveshaft's splines, or the pinion yoke on the rear end, or the yoke on the back of the transfer case, or all of the above?
And no, it's not normal. Same as my first answer. There should be virtually zero play in the joints, and just a tiny bit more in the splines. A little rotational play in the two end yokes is normal, but here again, it's just measured in thousandths of an inch in some cases. Even worn ones might be a 1/4" unless you've got a locker in the rear end.
Yours sounds a bit excessive. To say the least.
And just what led up to this? A new lift kit? Some other change? Or did it just start making a noise/vibration when you were just out driving it? Did it come on slowly, or all at once?
