Yukon 3rd Member
RonJones
A while back I bought a Yukon 3rd member with Grizzly locker. It comes without a yoke, but has the seal (but no oil slinger) installed. Do I just need to install a yoke and torque it to 200 ft-lbs, or do I need to disassemble the pinion Assyrian, remove the seal, set pinion preload, install new seal +/- oil slinger, and put the yoke back on?
R
RonJones
So at the very least I need to buy a pinion assy o-ring to figure that out.
I would think at the very least you should call Yukon and find out how they built it.
Seems to me that if they went to the trouble of selling a third-member without a yoke, but installed the seal fully, they don't expect you to have to pull it apart to do anything.
It's possible that you will have to, but it would sure be nice to simply install a yoke and be done. So I say it's worth the call.
Hopefully theyr'e open on Saturdays though, so you don't have to wait.
Any reason you remember you got it without the yoke installed?
R
RonJones
I bought it from another fellow who got it from JBG; apparently that’s how they sell ‘em.
Ok, thanks. I'm going to be ordering one up fairly soon and want to make sure mine's complete (with yoke) if it's offered that way.
bigjhoov
nobody
You could pull the pinion assembly and see what's between the bearings....
Yeller
Rogers County Oklahoma
Since it has no heat cycles the oring is reusable. Just pull it off the center support and inspect it, it's not so much about looking at it as "excercising" the rubber, it will be just fine.
R
RonJones
So, if it’s a solid spacer, just install yoke and torque to spec, correct? Otherwise, new crush washer and set up the preload?
Depends on if the crush sleeve has already been crushed. Or put in a spacer kit while you have it apart.
R
RonJones
Should I have to press the outer bearing in order to remove it? It’s been about 40 yrs since I’ve been into one of things, and I don’t recall having to do that.
R
RonJones
So it is. The pinion assy does have a solid spacer/shims in it so I’m gonna reassemble and fab a yoke bar, then torque it to 200 ft-lbs and call it done.
R
RonJones
Here’s what the inside looks like.
WILDHORSES
USA
That's a solid spacer. Don't forget to check the back lash and gear pattern. Never understood selling third member without a yoke.:cool:
Jim
