ZF or M5OD
jjohns508
Looking at doing a 5 speed swap but having trouble deciding/finding the transmission I want to go with. Found several M5OD that came out of a 6 cylinder f150 just not sure if it will bolt up to my 5.0. I know the M5OD's are easier to come by and less expensive. Not to mention the dana 20 adapter will work on either ZF or M5OD. Any advice on which one to go with.
siderbox
The 300 6 cyl has the same bell housing pattern as the 5.0 and 5.8 so your good there.
Now it's just pros and cons to each, then decide.
ZF pros
Stronger
lower low gear- Could be in ether list
ZF con
more money
Bottom line for me was if I went M5OD every time I drove it I would be a bit mad that I didn't do it the way I wanted in the first place.
I would hear my Dad's voice "Do it right the first time if you don't have time. There's always enough time to do it over."
WorkerBee
Northern CA
I mulled this decision for a long time as you probably are. I previously had the NP435 and did not find the granny gear very useful for my style of driving. I settled on the M5OD because I found one at pick n pull for cheap and I was willing and able to pull it.
So far I have been very happy with it. I think it was rebuilt at one time because it already had the metal shift rail plugs and seemed very tight. For 100 bucks I couldn't pass it up.
The only real complaint I have is that the reverse gear is really tall. So tall that I put it in low range to back it out of my shop. Lower gears in the rear will help that but that's a few projects away.
I mostly drive on the street and don't have a 400HP motor. So for me it's a great fit.
Rymadd
How much power are you going to be running? And what kind of driving?
M50D is rated for 330ft/lbs
ZF is rated 420-470 ft/lbs depending on which one
I did the ZF S5-47 because I will eventually be on 37s with a 408 stroker and want the beef!
J
jjohns508
Thanks for all the tips guys. I pan on mostly street driving and some mild trail riding. As far as power I was told the motor have a fresh rebuild on when I bought the truck and the guy calmed 400 hp but I highly doubt it won't really know what I have until I get into it to replace a rear main seal. I do know it would smoke ;D the 33's the guy had on it.
