- Dec 26, 2006
- 2,469
Looks like you have more than enough good ideas but have you considered a narrowed HP 44? I'm guessing it wouldn't solve all of your issues but it sure would help quite a bit.
DirtDonk, you are the man sir.
How do you feel about tapping new holes in the frame vs putting a sleeve in there?
Sent from my iPad using Tapatalk
would a rivet nut work?
...Would a rivet nut work?
Maybe...I haven't done much sheet metal design work in a while, but if my memory serves me correctly, most of the sheet metal thread inserts don't go beyond 3/8-16 fasteners, and smaller on some types of inserts, so what size fasteners are needed with those crossmember bolts?
i ordered the same cross member and sent it back. had the same problem. i think this cross member is used for another transmission, they tried the dual use but failed. seemed like the tubular version was ok but they said they had problems with the machine shop. i am still trying to figure out how to build one.
Did you ask BC what the 2 extra slotted holes on the bottom are for?
Go to a site like RuffStuff and buy weld in nuts
https://www.ruffstuffspecialties.com/WELDWASH.html
Cheap & work great.
Cheap & work great.
I shimmed the trans up about an inch and mine now clears
TK, do you have the same cross member?
