pcf_mark
- Jun 11, 2010
- 3,584
I have my new fancy aluminum tank installed with all new lines (rubber and metal). I added a 3/8" vent to the tank for both fill and accommodate expansion of the fuel when temperatures change. The current vent goes up into the driver side rear wheel well above the filler neck and has a 180 degree bend to keep dirt and moisture out.
I want minimize vapors from evaporation building up in the garage. This valve from Dorman (GM knock off) might be the ticket
https://www.amazon.com/dp/B001C6JCLE/ref=psdc_15728221_t1_B00252QIKM
I have plenty of air volume in the tank to accommodate any reasonable change in volume during most running conditions. But the rig sits inside for a week or two at a time and I get a little odor from evaporation. This valve from what I have read has a 1 psi limit - once the pressure on the port reaches 1 psi it opens to the other port. I think this will eliminate evaporation but allow it to vent on a really hot day as need but close again automatically.
Anyone try this?
Anyone try this?
