With the exhaust done I could now see where everything needed to route. I ended up running the fuel lines, pump and filters along the upper outer side of the drivers frame rail. I didn't really have any other options for mounting or routing than what you see, but at least it's easy to get to if need be.
Also, slednut10 stopped by to get me started on the engine compartment wiring. He was a huge help in wiring up the alternator and setting me up with relays for the fuel injection and coil power, thanks Art!
Once the wiring was sorted I wrapped it all up and installed the plug wires. I also drilled and tapped the boss on the water neck to accept the original temp gauge sender as the unit from the sniper took the spot on the intake manifold.
Still a ways to go but real close to firing it up.
