- Mar 8, 2007
- 81,779
those always seemed to be a good brand for the $$ hmm
Pertronix in the dual point would eliminate the constant maintenance issue. Been looking but haven’t been able to find a correct stock single diaphragm one. Not sure exactly the best place to look and not exactly sure what part number to look for.
Blue connector has 12.5 volts in on position and 0 in ACC. So I’m guessing I would run a bullet connector and wire from the blue wire to the pos side of coil. Hook pertronix red there as well black wire to negative side and just not use the factory red green wire??I think I see the resistor wire going straight to the ignition switch on yours. To bad…
But I also see a couple of unusual red with blue stripe wires under there as well. Normally you will only see one on a 72 model. Maybe they were just some cuts and splices as it looks like, but it’s interesting so I thought I would note it anyway.
The blue wire under the hood is probably for the old anti-dieseling solenoid. That might work, but easy to check with a voltmeter.
See if it’s got power with the key in the on position and in the ACC position. If it’s hot in the ACC position, you probably don’t want to use it.
If hot in ON only, you’re good to go.
So that big wire is the ambient switch circuit? Wow, that’s heavy gauge. Wonder why…
How would you compensate for this particular situation stronger spark lower advance? Same way just adjust timing or something else? Also seems to idle faster and the exhaust doesn’t smell as clean.It's also got a stronger spark most likely, which in some cases might actually act like this at a lower ignition advance than with the old weaker spark. Not often, but it's possible.
Just checked timing at idle granted it idles fairly fast right now I’ll have to hook up my tach and dwell meter, but it seems to be around 1500 or so. Took longer than usual to crank but cranked right up. Used a dual back timing light and got 44. I don’t know anything about dual point distributors but know that’s way too much. Don’t hear any detonation, but I’m also thinking like you said the timing marks are incorrectly located. It’s the original engine but I’m sure front components have been changed. Had a Ford 428 that I had to tune by ear for the same reason. Using the numbers and marks was completely unreliable when you tried to time to spec.Yes. If your combustion chamber reacts that way to better spark, you simply retard the ignition timing. You should (again, in theory) not have to go lower than stock specification, but if it was already bumped up a bit like most of us do, then rolling it back a couple of degrees should do the trick.
But chances are better than even that the new install simply advanced the timing a bit more than the engine was happy with. At least that's my story and I'm sticking to it.
The other common ignition timing scenario on our particular engines (289, 302 and 351 Windsor) is incorrectly located timing marks and/or pointers.
If yours is an original engine with all original front belt drive assembly and original damper, then the timing marks should line up perfectly with the pointer. Unless the damper ring has slipped...
But if any of those things have been changed in the past, all bets are off until you verify that the pistons, damper marks and timing pointer all match up correctly at TDC.
Too many variables until confirmed.
What should the timing be? I dropped it to 20. Cranked right up and smooth. Went to 15 didn’t idle as well still cranked right up. Went to 18 little smoother. Exhaust smells much more normal and it has a tough sound. Is 18-20 ok? Most I think are 10-14. Think stock is 6 but there’s just no way with this one to get there.With 44° you are probably not getting any detonation as you are getting a full burn before TDC. Timing so advanced you don't get it.
And that will be a hard starting engine if the ignition is any good.
You can get some wild timing settings when "tuned by ear" and vacuum gauge.
If I drop this one below 18-20 initial it splutters mid range. If I blip the throttle seems overwhelmed and splutters unless I raise timing to that range. It acts like it wants more but I’m afraid to do that. I went 10,12,14,16, 18, 20 and with each step, idle got smoother and the mid range splutter was less and less.My 75 w/302 and Holley 4160 has initial timing set at 14 and total mechanical at 34. I know the timing marks are correct. I have played around with initial timing anywhere between 8 and 18. I've never noticed any detonation or hard starting at 16-18, but backed off to 14 because I didn't notice any performance gains and didn't want too much total advance to be safe. 14 also works well with my idle speed and having the transfer slot adjusted correctly. Its funny how very similar engines like different timing.
