I was told I may have to rejet it to use a Pertronix, but I'm not sure what's in it currently or what way to go.Some of the things you describe could easily be fuel related.
A lean condition from either a vacuum leak, or lean overall jetting, or not enough accelerator pump squirt.
Idles and cranks great, takes fuel well except light throttle can hear and feel a stumble/miss. I may need to go back to points. Not sure what to set them at if I do I'll have to research specs unless someone here knows. Not familiar with dual points.
Shouldn't be any vacuum leaks as nothing has changed in regards to that. Really only one thing has been changed points to pertronix. Accelerator pump possibly due to fuel with ethanol in it, but doubtful.
What about the vacuum cleaner noise? Wasn't there before this. Sounds like it's coming from the distributor itself or possibly carb area. Plug wires are suppression type.
