So, I have a new Prop valve from Nick @ NorthEastClassicFordParts as seen here: https://northeastclassicfordparts.com/1966-1977-bronco-brake-parts/1687-brake-proportioning-valve-disc-drum-1966-1967-1968-1969-1970-1971-1972-1973-1974-1975-1976-1977-early-ford-bronco.html
Have the full SS hardlines and flex lines from WH.
The damn adapter on the prop valve wont work with the ss WH lines. %)
What I need is a 9/16-20 x 7/16-24 inverted flare for this stuff to work together. I cant find that size ANYWHERE.
No way can I be the only guy that has had this problem......
comments?
L.R.
comments?
L.R.
