How long a list do you want?
Stock LS, like 300 HP? Can't remember on your thread if it's a 4l, 6l or ??
Paul mentioned a couple of these-
Street use-
- 28 spline axles. Broad defiinition of spirited but maybe last a week? Depends on tire size, hardness of rubber, locker or clutch type rear axle for how long they will last
- 9" yoke/rear DS joint, this would not be an issue if you kept axle wrap 99% controlled but if you have a soft style suspension and good power and can transfer it then the rear yoke is going to point to the floor and you will waste it and your DS
- D20 rear output. They are SOOOO weak. Upgrade b4 you even test drive it. I think I remember you having an Atlas going in?
What they were originally made for use-
- all of the above and
- D20 output, D20 intermediate gear and D20 case. Gear teeth will peel off like butter on a warm day with excellent torque and traction
- D44 axles and joints will just twist off if you back up with the wheels turned with ANY kind of traction. Add larger dia tires and a locker and "poof"
Not much left....
I grenaded all of these muliple times (except the rear yoke- I grenaded ARB carriers and R&P's
