IMO I have no preference on gear supplier. Some are a little quieter than others and some ratios are quieter than others. For you prescribed use I’d bypass any locker and go with a Truetrac, which I see you selected.
Can't go 14 bolt now? Save a TON of money doing it once? Just asking.I hope you’ve got the Atlas 2 transfer case. The input shaft on the Atlas 4 is not chromoly and is at risk with a high-torque engine when the planetary is engaged. The Atlas 2 gets the same input shaft, but since there’s no planetary it will see 1/3 of the torque. But if you’re not really wheeling it you’re probably fine either way. Also, the Atlas 4 would give you a difficult driveline angle.
I’m in a similar situation. I’m building a 630 hp engine, and I’m going to wheel it for a couple of years before adding a 14 bolt rear end. With the bad history nvrstuk had with his 35 spline ARB rear locker I’m going to install the competition ARB (RD99CE). This adds $1K to my axle, but will give me peace of mind. I’m not sure how strong the other lockers are, so I can’t comment there. I’m going to sell my whole rear end in a couple of years and recover some of the expense.
If you can swing it go with a 14 bolt full floater in the rear and a WFO Concepts torque arm and 1350 u joints. That will handle lots of power and if you were to break an axle you won’t be screwed.Back in my HP289/271 solid lifter days with my 3 spd, L70x15 tires I never ate a ujoint, never had pinion rotation issues (stock springs), never grenaded an output shaft and I would literally eat 28 spline axles when shifting on pavement.
This was decades ago but I remember twisting off over eight, 28 spline axles and just always drove home in fwd. That only lasted till '85 because that's when I built my 351W and 200,000 miles later I never ate another 28 spline till it twisted off 31 spline axles because of low gearing crawling up stuff with doublers, 6+:1 first gear, 37"s, lockers, etc. Torque would just twist stuff off at low speed.
All history now...
BTW, I have a spare, brand new 9" Nodular housing w/Daytona pinion support for sale.
Well, you asked and I've been known to give my opinion out (even when not asked).Heck if I know...... I'm a 61 year old Bronco rookie. How would I identify what I have. Does my OEM (MARI) build sheet tell me that answer or do I need to get pics for our experts to continue guiding me?
BTW....thanks to everyone that's helping me. Truly appreciated.
If I go with the 31 spline option, will my existing stock housing work? That is a cheaper option for sure if the 35 drives me to a new housing. At some point I have to start minimizing my project cost & scope creep. I tend to go all in for the best, but often good enough works.
Me and LOT's of other builds with gobs of torque were destroying 35 spline ARB's. Yes, some were due to the design of the engagement dogs inside and inappropriate application & tiiming of air supply engagement but there is not much meat inside a 35 spline ARB so the comp model IMO is the only way to go. Also 3 different ARB guys that I know from early, early ARB days that go waaaaay back with ARB confirmed what I just said. I would never run another 35 spline non-comp model with 40" or larger tires in severe applications knowing what I learned.I hope you’ve got the Atlas 2 transfer case. The input shaft on the Atlas 4 is not chromoly and is at risk with a high-torque engine when the planetary is engaged. The Atlas 2 gets the same input shaft, but since there’s no planetary it will see 1/3 of the torque. But if you’re not really wheeling it you’re probably fine either way. Also, the Atlas 4 would give you a difficult driveline angle.
lolDon’t tempt me. I just want to get this rolling and if I go full-width in the rear I’ll have to do it in the front. I was hoping to find the path of least resistance before I go crazy on my axles (in the future).
But I guess for the price of a third member I could find a Dana 60 to keep that spot warm for my 609. It would be cheaper but take me longer. Decisions.
Regarding the Atlas decision, you missed that conversation 6 weeks ago on my LS build thread. I had reached out to Novak and Advanced adapters and they only had one suggestion, an Atlas. I found another Transfer Case builder who told me to go with a GM NP241 with a short yoke. The 205 never really came up in discussions with these guys because of the HP concern.Well, you asked and I've been known to give my opinion out (even when not asked).
So-
I gotta ask... if this build is for the street only then save THOU$AND$ by not buying an Atlas. IMO from knowing only what I've read here, there is absolutely no need/use for an Atlas. You want something that is super strong and looks purdy???? Then powder coat an NP 205 case and once again, save thou$and$ by not buying something that is not needed.
OK, you have a 4:1 first gear in your 6l auto correct?
You have a torque converter (and you know you get about 2:1 gear reduction through a good converter right)
You have truckloads of torque off idle
You have little to no use/need for low rock crawling gears for 4 wheel drive with your 4:1 first gear and TC
You need something that will handle ANY & ALL abuse you can and want to dish out
You want to save some cash
If you add all this up the 205 does all this at a $2,000 dollar savings- at least.
Can you tell us why a 205 won't work for you?
Seems so obvious by what I know of your build I should have mentioned it earlier.
... and going with a 205 is not "giving up" anything, it's the wisest decision you could make so you can spend that $2,000 + dollars somewhere else
Agreed! The 205 is a beast. They used them in monster trucks for gosh sakes! I have the Blackbox Titan (thanks for selling that to me brand new!) and a 205 behind my 408W and 4R70W, and I hardly ever use anything but the “pathetic” 1.96:1 low range in the 205. And mind you, folks, I snow wheel (or at least attempt to) with NVRSTK, so I sometimes have to beat on my rig to keep up lol. And the 14B is pretty much a no-brainer too. Cheaper to build than a 9” and there is no comparison when it comes to strength. You get a better pinion angle to boot! I narrowed mine 4” just by using dually hubs.Save thousands on the 205. It's stronger than anything out there that fits, except the brand new Atlas.
You would save "tons" of money on the 14 bolt. No truss needed either.
$3500 compared to the parts I listed in my last post. I am late for an appt but will check in later.
Just good options. I got my last two housings for under $100 each. Shaved them and bought the new cover for $120. gears and locker isn't very spendy
A 14-bolt is NOT overkill for 500hp and the fabrication involved is very minimal.So another curve ball on rear end options, and I’m more confused. The 14 bolt option clearly has more strength, but it doesn’t look anything like a simple mod and a bolt in option. Following your thread, there seems to be lots of fab required work plus a lot of knowledge required to support the fab work. It also looks like this is overkill for my needs.
Earlier responses felt like for street cruising the 31 spline option worked fine.
Am I reading this right, or am I missing something.
