Nothing Special
- Nov 25, 2016
- 805
The Bronco's brake conversion is done! I bought the hoses from the GMC power steering pump to the hydroboost unit and from the hrydroboost unit to the GMC steering gear. I also bought the hose from the Bronco power steering pump to the steering gear (actually the hose for a '70 F-series truck). That gave me all the fittings I needed, but not all on the right hoses. So I cut the hoses and had an industrial hose supply shop put them together they way I needed them. Not a cheap option, but it worked. I added a power steering cooler and T'd the return lines from the hydroboost and the cooler at the pump. That took care of the power steering fluid side.
At that point I needed to put the Bronco on the back burner while I worked on my parents travel trailer for a while, so this next update was delayed.
I got a new proportioning valve for disk / drum (since I was going away from disk / disk) and made all new brake lines. This evening my wife helped me bleed the brakes, so it's done!
I didn't take it for much of a test drive, because I don't have insurance on it, but the brakes come in a lot higher than they did with the vacuum power / 4 wheel disk setup. (One of my complaints about it was that the pedal was almost on the floor in a moderately hard stop. It always did the job, but it never inspired confidence.) The brakes are a bit touchy now, but they don't seem horrible. I think I'll be able to get used to modulating them easily enough.
Also I probably don't really have the rear drums adjusted correctly yet. I had intentionally left them "loose" so I did a few hard-ish stops in reverse to try to get the adjusters to tighten them up a bit. On the first few stops I locked the front brakes pretty easily. But after a few I was stopping just as hard without locking the fronts, so the rears must be coming in more now. We'll see how things go once I actually get it on the road.
OK, I said the brakes are done, but that's not quite true. I still need to do a little clean-up underneath, making sure the rear brake line is tied up appropriately. And even though getting a working parking brake was one of the driving forces in this project, I still don't have one. My air tank is in the way of the parking brake cables and even harder to address, my roll cage is in the way of the parking brake pedal. Both are surmountable obstacles, but both are going to need to wait a bit.
The next project, and the reason I'm not putting insurance on it just yet, is adding some rocker protection. Both rockers are rusted and crunched, but the passenger side is so far gone that the body is sagging to the point where the door doesn't operate correctly. So my plan is to cut away the rusted / crunched sheet metal and weld in some heavy-wall rectangular steel tubing. Hopefully I can get started on that project in the next few days...
