harleyabarton
hey guys so i have a newly fully restored 75 bronco and i just supercharged it. i have only driven the car 330 miles before installing the supercharger... after i install the supercharger the alternator no longer works. so i test the alternator and sure enough its not putting out any volts. so i replace the alternator. this is a gm style 1 wire alternator. it has the little 2 prongs on the side that arent being used.. ive used this same type of alternator on my other 2 broncos with no problem! so i replaced the alternator and still nothing! i go and take the alternator to the store and they test it and it tests corrrectly and shows that its in working order.... so i decide to replace my wires.. 1 wire from the got erminal off the alternator goes to the posetive side of the starter solinoid and then i connect the negetive battery terminal directly to the alternator like i normally do... still nothing... when i was replaceing the wires i had a discovery. the wires inside the insulation had severed and broken in half but the insulation was intact... so i replaced the wire. but this alternator that i just had tested still doesn't seem to read any voltage... my volt reader read about 12.55 volts to the battery and then if i put the tester directly to the alternator hot terminal it still reads 12.55 volts... why is it testing postive but then not working on my truck!!!???? this doesn't make any sense... i did all the right things even reved the engine to around 3500 rpm and held it there just to see if it would kick in but it doesnt.. is the alternator suppposed to only kick on under a certain amount of volts??? my other trucks ALWAYS read 14.5 volts! what is wrong with this thing!!!!!
