1 wire alternator problem
harleyabarton
Jupiter
alright yall ive been on here before and mistakenly had a 3 wire when i thougt it was a 1 wire... but now i have a 1 wire wich was running on my 78 for 6 months... ran perfectly. this is a promaster 150 amp alternator and is a lot of money. ran perfectly in my 78 but now that i put it in my 75 it stops working... if i disconect the wire from the alternator to the battery the wire from the alternator reads the correct volts... 14.5V. as soon as you touch that wire to the battery it goes down to 11.6/11.8. starts lowering the engines idle a bit as well. is this alternator over exciting? whats wrong with my car? i even disconected everything from the battery except the starter and ignition... change it to just about 12v but not nearly enought to charge the battery.... why does this alternator work when not plugged in or even work when in my other truck but not in my 75... ive had this sort of problem with 5 other alternators. first a 1 wire then 3 different 3 wires... all working for a short time then not at all. the wires are all brand new its a fully restored bronco from the ground up with american autowire wiring harness. no shorts seem to be accruing sense when you attache the negative terminal to the battery it doesnt spark almost at all..... also the pulley is very hot as if its slipping on the belt but it doesnt sound or look like its slipping.
