1969’s build thread
1969
Reno, NV
WFO coilover mounts, and track bar mount
BanditBronco
In terms of what? I’ll run a PSC ram
If you plan on running the static side of the cylinder on the passenger side usually gets a little tight with everything. I have seen a lot of people use the track bar mount for both the bar and the ram with multi hole brackets or I like to use a rear jeep bracket with multiple holes. I am personally not a fan of static side of the cylinder mounted on the diff cover. I was just curious if you had ideas yet on how you were mounting the cylinder.
1969
Reno, NV
Oh I see what you’re asking now. Yes it will be mounted off an aftermarket diff cover. Never had an issue with doing that before.
Yeller
Rogers County Oklahoma
nothing wrong with the diff cover option. I have had to go to lube locker gaskets to keep one from leaking. I think on that particular one it was an issue with the cover bolt holes being too large allowing it to slip a tiny amount side to side
1969
Reno, NV
Moving along, just waiting on the frame plates to show up from the CNC shop now.
1969
Reno, NV
Who's track bar bracket is that? I am also very curious to know how the articulation is on this set up. My radius arms with Balistic joints bind quite a bit as expected. I'm running the 79 D44 housing with cast on wedges, so not easy to change.
WFO Toyota Tacoma track bar swap bracket
1969
Reno, NV
Not exactly ride height but you get the idea. Still waiting on some stuff to finish up the front before moving to the rear. 37” Yokohama Geolander MT on 17x9 pro comp wheels
1969
Reno, NV
Got the 3/16 frame plates back from the cnc shop. Going to plate the entire outside of the frame with them.
1969
Reno, NV
3/16 frame plates on the front.. again will re-spray it with steelit. Coilover towers next.
1969
Reno, NV
Going to drop it down to a 1” body lift from the 2”, and probably in the future go from the 3.5” rear spring to 2.5”. Still missing a lot of the weight it will have once done.
