1971 Boss 351C new buy
fordfan
Hey Fellows......cool engines and smak talk, but I think 351boss is thinking about the engines I just snapped pics of. These look good in their disassembled state!
bax
Old Member
Hey everyone! It looks like Fordfan has a few open chambered big block chevy engines.
I just had to go there. Fordfan I have a set of close chambered big port heads that will fit on those chevy's
351Boss
Honolulu
I didn't just "bugger off"... I have been reading this thread a lot and trying to figure out what I have. This is all pretty new to me so when y'all give me a tip I try my best to use the information, not just brush it off. Believe me I gave learned a lot, for a newbie like me any information is a learning experience. Of the 335 series motors there is 351c, 351m & 400. From what I've gathered mine is a 351c. Now if there are different types of 351c's, well then I wasn't aware of that.
Deano
There are 2 and 4bolt main blocks and 3 or 4 different heads for them!
bax
Old Member
OK more info to help muddy the waters.
351C Engine Block Casting No. (4-bolt mains)
1971 ............ D1ZE-A (Boss 351)
D1ZE-B (Boss 351)
DOAE-B, DOAE-D, DOAE-F, DOAE-H
1971 - 74 ......D2AE-CA (Cobra Jet)
1972 .............D2AE-EA (high output)
351C cylinder heads were 4 types, small or wedge chamber with big ports (4-V), open chamber with big ports (4-V), open chamber with smaller ports (2-V), and the austrailian head (small chamber small ports)
351C HEAD Casting No. (4-V type only)
1971-74 (74 - 77cc open chamber) ........DOAE-E, DOAE-M,
1971-74 (73 - 76cc open chamber) ........D1ZE- DA (CJ), D2ZE-A (HO), D3ZE-AA (CJ)
1971-74 (61-64cc closed chamber) DOAE-J, DOAE-G, DOAE-H, DOAE-N, DOAE-R, D1AE-AA, D1AE-CB, D1AE-GA, D1ZE-B (boss 64-67cc)
fordfan
D1ZE-B (Boss 351)
You maintain your Integrity!!! You Ford Engine Sleuth You!!!
What about a stroked, aluminum headed Cobra Jet Cleveland? I know you have comments!
351Boss
Honolulu
I was finally able to locate the casting numbers: D1ZE-B. thanks for everyone's help. I know it was a long and bumpy road and some learning on my part. But I really appreciate all the help!
bax
Old Member
Your going to make me tell little secrets.
yes 96=/- sets of these were made part # SK 42624 heads were the factory cast aluminum Cleveland heads made in 1968. ... 68.5 they were designated "Cobra Jet" There were made but were not put in any production vehicle. If you have a set of them they would of originated from the drag racing big boys of the day. Also to add, there were aluminum Cleveland blocks made. part # sk42617 Also less than 100 produced by ford. I have never seen any of these pieces personally but here are some pictures.
FRANKO289
Bronco enthusiast
very interesting thread and lots of good info ....
now what about one w. SK5xxx ( i was told its one in less then 100 ever made ) ?!?
bax
Old Member
Thats a cast iron block. Could be far less than 100 made. From what I have read there were several castings before the final design for the aluminum block was cast. It bears the sk brand and the solid freeze plugs but it is missing the added bosses on the edge of the deck for the added head bolts. Very cool Franko, And of coarse you know this guy correct. He has 3 of them and a balloon yada yada. Your amazing.
FRANKO289
Bronco enthusiast
Not quite ! yes the head used 14 head bolts !
since i have not seen any engineering books w. anything after sk510000 i was just wondering if you had any info about the later once .. thats all !
were they all experimental & nascar specific ?
bax
Old Member
No not nascar at all The blocks and heads were to be used in Can Am and Indy cars, as a 320 inch motor. I have read that some of the blocks were cast with the smaller windsor main journals. These were for the 320 cid engines. Dyno Don used them in drag racing where they were a much bigger 400 cid. I think some of the NASCAR guys got them too. After Ford quit the development of the cleveland for racing most of those trick parts went to Holeman & Moody including all the remaining alum. 351C blocks and heads. And then Holman & Moody sold them to the public or any Ford dealerships that wanted the stuff. So thats how the parts leaked into the publics hands. its funny that ford spent all this money on an engine, made all the trick parts and the aftermarket did not even try to pick these pieces up and reproduce them. All the work was done all they had to do was copy it.
broncogt
I have a 400 that has 351c /w engine mounts? how did that happen?
Ok, sort of on topic, you have one of the odd ball 400s with the small block tranny pattern. I suspect they are rare too....
bax
Old Member
Yes I do. The blocks have dual mount options and the small bell. I found a few of these because I wanted to run a automatic overdrive trans. Only problem is the 400 does not get along with the aod's. so the c6 is doing fine with the 400.
Deano
I wanted to put a AOD behind my 351C and was told by a few shops it wouldn't hold up. I don't understand why they would say that any ideas
