looking to buy a 2 post auto lift. what the best quality brand for lowest price.
I would avoid the screw style, go hydraulic.
I also prefer the top crossbar. Make sure it is tall enough. There are some that have open tops but the synchronizing system is on the ground. They suck. Always in the way when trying to use a transmission jack or just about anything at ground level.
Keep in mind that a Bronco isn't that happy on a 2-post lift. The front legs are too far back to lift by the frame and they are not the most stable picking up by the radius arms. Radius arm lifting also prevents suspension work as you are still loading the suspension as you lift. More than one bronco has nosed off a lift. You will need hoist jackstands, and use them.
As for brands, a lot really depends on who is local and what the local distributor puts up.
that's the one I have been eyeballingI have an Atlas 2-post 9000 lb lift from Greg Smith and it's worked well for 4 years. I know its not American made but for the limited "hobby" use that I do it has been great and priced right. I have had no issues lifting early Broncos, full size Broncos, Wagoneers, and TJ and JK Jeeps on it. It was easy to install with the help of a buddy or 2.
I welded on lift points to the frame just for the 2 post
Nice man.. like that idea
