3-G install ?
krunchytaco
Carlsbad,CA
I picked up a 1 wire 3G alternator from a friend,I cant seem to get instructions on the correct install for this unit..I believe it came from "BCBroncos".
Does any one out there have the instructions that they could send me , or walk me through it?
Thanks, Eric
broncow72
Village Idiot
Spring,TX.
Thanks, Eric
Hey Eric. PM me your phone # and I'll help ya.
nutter3
From BC Bronco website
Try this
  • 3ginstall.pdf
RRRAAAYYY2
Brantford, Ontario
What are you protecting with them? If the rotor goes open you have a 5 amp draw, if a diode shorts its stem will only handle 70amps max. The only thing you introduce into the system is a battery disconnect if the alternator is charging at full max. If the breaker goes off in that case, then you physically will blow (sometimes explode) the diodes out of the rectifier.
I am not totally against fusing an alternator, but if you are going to do it, make sure it is with one above the max output of the alternator, in the case of a standard 3g I would use a 180amp breaker.
And if you are actually going to prevent anything, then you should have one right at the alternator and one right at the battery. Only downside to this is that the alternator will have to use the sense wire directly to the battery instead of through the main battery cable, as the two breakers will give a voltage drop over time and cause the regulator to over charge the system.
broncow72
Village Idiot
Spring,TX.
So you are saying I'd be fine with nothing between bat. and alt.?
krunchytaco
krunchytaco
Carlsbad,CA
nutter3 said:
Thanks Guy's,
According to "B.C.'s" diagram,it needs a 175A inline fuse between the + side of the solenoid!!
As for the wire that runs to the starter switch(from the alt.)is there a wire in O.G. harness that I should tie into? Versus running a whole new wire to the starter switch?
RRRAAAYYY2
Brantford, Ontario
What I am saying is I really don't know what purpose it serves. I think the pros out weigh the cons might be a better way to say it. The only thing that the fuse can protect you against is the main battery cable going to ground. Which can happen. But if you are only using 10 or 8 ga wire, probably not enough amperage can go through the wire anyway to pop the fuse. If you are using 4ga or bigger the arc from the short is going to be huge and likely blow things apart anyway.
The main battery cable would be better suited going directly to your battery instead of the solenoid as well. This will make everytihng that the alternator produces have to travel to the battery first, before the rest of the system. The battery will clean up the DC so that there is no excessive ripple.
The wire that you are told to take to the "I" on the solenoid, would be better tied into your old regulator harness. Find a wire in the old plug that has nothing with the key off, and comes live with the key on.
