At 70mph would be 3279rpms with 35's and 4.88's not bad good power to the ground! Ratio x speed x 336 divided by tire size. Pick a speed you like to cruise at and stay around 3000rpms
Oh with over drive youd be just fine for cruisen then!, that would drop the rpms down a good bit disregard what i said! LOL i didnt realize you mentioned overdrive that math was all for 1:1 ratio. Also i found engine build article again it was a 302 from 91 mustang all stock and they didnt test differnt carbs like i had first thought. But it made right at about 400hp at 6000rpms and well over 300 ftbs at 4000rpms stock cam! Just Heads,headers, intake,and roller rockers all added one at a time making differnt HP/tQ numbers. Pretty cool read.
Ya thats were things get tricky remmember thats peak HP at peak rpms but you can bet that the HP and torque is much more than what it was stock at the lower end too. Then Add the RV cam you mentioned and bingo youll be set. You can basically get good ideas from that build up even minus the heads add everthing else plus your as mentioned cam and youll be fine. A 302 small block will have to spin a little more RPMs to see most power gains A healthy 302 thats all done at 6000rpms is really not crazy at all! its about right. But thats were the gearing helps take avantage of the HP too, but mostly in the mud were keeping the tires cleaned out is important. I guess im trying to say is you could have a motor that takes full advantage of its power in all aspects of its rpm range. From low to high.
Just read the entire thread. Great read, a lot of good info here. Thanks.
Glad my questions could help someone else. What are you thinking about doing?
At the moment, nothing. My 33's and my 3.50 are keeping me happy. Mildly messaged my 302. New intake, 4 barrel carb, rv cam, split the exhaust through magnaflows (nothing to prove this, but my seat of pants experience, but it feels like I'm running around 180-200hp). I run between 2200 - 2400 on the highway. Still feels punchy taking off at lights. Oh, 3 speed auto.
So far so good. The 4.11 idea sounds interesting though.
OK i guess i can start since im still up and goofing off. Hehe. Basic 302 block. .30 over, flat top pistons. 1968 302 heads with the factory adj rockers (smaller combustion chambers= more compression) Cheap long tube headers with dual exausht and turbo mufflers, Edlebrock 289 streetmaster intake its an old school single plain intake with small runners works about as good as dual plain manifold. Old 1960's Holley vacuum secondary 4150 series 600cfm carb, Crane RV cam (nice little lopey idle) Factory dizzy with factory electronic ignition. Stock waterpump, 195 t-stat, Champion Alum radiator. Stock C4 with a shift kit, 4.57 gears and 31's. Overall the truck runs really well! Tends to get about 13MPG on road trips cruisen 60mph
