Like said already... The 72 bronco 302 came 140 hp.. You should get a bronco graveyard catalogue, its got all the important info in the back..... Now for the fun, theres a list of upgrades you can do to raise hp without really sacrificing low end... Things like going to four barrel, however getting an after market manifold in itself will raise your hp. Get a master rebuild kit... Replace your cam with a good rv cam for some helpful low end, plus itll sound good. While your that deep change your pistons to flats... I had my heads professionally cleaned and had them shaved down a little which raised my compression... If your going more for hp. Go shorty headers, if you want a little more low end go long headers... And top it all off with a good exhaust system... And then for an extra couple hp. Put a fan clutch, or electric fan in... That will definatly get you way over 200 hp.....
I warn you though it gets expensive..... Im only half way with my engine rebuild, and i ve cleared 2000 dollars easy. So shop around find the best deals... And decide what you can or cant live with.... Good luck...
Oh trust me i understand the snowball that is a car project
There seems to be two schools of thought. One is build the powertrain and then build the rest of the vehicle. The second is to build your drivetrain and then build the powertrain around it. Why do i keep thinking about a Cummins in an Early Bronco... maybe the bronco just doesnt make enough noise for me
