302 Cam Choice?
Zillacon
Hackin Away!
While I have our 71 302's motor torn apart for a 4bbl intake and carb I would like to put in a little bit bigger cam. What is a good streetable cam for a stock motor that you folks have had good luck with. It has a manual trans.
1970mule
i just went with a cast 351 cam. it just changes you 302 into a H.O. 302 so just need to change the firing order from 1-5-4 to 1-3-7.. easy as cake
TDubya
Fortuna, CA
I'm running a Crane H-260-2 with a 4 barrel and stock heads and am happy with the performance. Good idle, torque and economy.
broncnaz
If the engine is still in the bronco you cant change the cam without either removing the grill or Cutting a hole in the grill. That said a lot of people use the edelbrock performer cam with good results. I run a crane cam with similar specs to the performer cam.
TDubya
Fortuna, CA
I was able to change the cam in my Bronco without removing or cutting a hole in the grill. Didn't pull the motor either. It was done about 12 years ago, so I don't remember how difficult it was, but don't recall any problems.
broncnaz
I think the only broncos with V8's that you might be able to swap the cam in with no problem would be a v8 conversion that wasnt done correctly. Last cam swap I did in the vehicle I needed to loosen one side of the grill to get that extra needed clearance.
jdowns67
Owner since 2001
Wilmington, NC
Just take off the front of the grill. I had the same issue a while back and was glead I decided to take off the front instead of cutting anything. It was easy.
JD
