302 cam choice?
la hi
What cam did you put in your 302 when you rebuilt it?
1966 U 15 bronco 170ci 6, 3 on the tree. Just purchased a 302 4v with a c4 transmission attached and I do not know where it came from. Even if it runs I will probably rebuild it after installing it. It will be a street machine with mild trail riding in Colorado with an altitude of 8,000 feet or greater.
blubuckaroo
Grease Monkey
Ridgefield WA
I've used the Edelbrock performer twice.
It's so popular that it's been cloned by most cam grinders. Just match the specs.
rguest3
Does your Bronco run now with the I6? I would keep it as is until you have ALL the parts needed for the 302 V8 conversion.
You will need:
V8 Frame Perches
V8 Radiator mounts
C4 with Adaptor for Transfer case and other Transmission related parts
My Cam choice would be the Comp Cam XE262H. If you are going to stay with the Stock heads, I would get the K-Kit with the Cam that has ALL the matching Valvetrain.
If going with Aluminum Heads, like the Edelbrock E-street 170cc heads for Flat tappet, then go with the XE262 Cam and the SK-Kit. This has the Cam, Lifters and Timing Set. Heads will include the rest.
Still going to need Pushrods and Rocker Arms. i'd go with Flat Top pistons to get close to 9.5:1 compression.
A 500-600 cfm carb is ok or a FiTech 400hp version especially for altitude and change of altitude.
Summit racing house grind cam, exact same specs as the Edelbrock performer but lowest cost. Same grind as a Ford Motorsports cam.
la hi
la hi
Thanks for the info from all.
Sorry about the 500 or 600 CFM, 1403 OR 1404 post. I could not find CAM's at Edelbrock I found them.
I will get the engine on the engine stand this week and find out what year it is. I was told it was 1980, but who knows.
Don't buy parts until you know what you have. If it is an '80 there is a good chance it is just a 255. Worthless small bore engine. Worthless because of the small bore you can only run the 255 heads which only have pin holes for ports. Better heads won't clear the tiny bores. Can't do anything with a 255.
edmedlin
Republic Missouri
220/224 @050 .512in/.512ex 112LSA roller cam. It gives you great torque at lower rpms. It will have a noticeable lope at idle. My 302 roller is from the late 80s-early 90s. I also run it with a Dart Pro 1 aluminum 58cc/170cc 2.02/1.60 set of heads. It dynos at 385hp and 400lb/ft of torque at 5000 rpms. It is already at 335lb/ft at 3000 rpms. The factory 302 was only about 120hp and 150ft/lbs of torque in 1975. Really bad time for V8s with all the restrictions. I run a C4 and a 2200-2400 stall converter.
Bore is something tiny, 3.6x" or something like that. Not the normal 4" of a 302.
That is the quick way if you have it apart.
If you just have the intake off, and the intake ports are no bigger than your thumb, it probably is.
I'm trying to think of what would have had a 302 and a C4 in '80. The fox body stuff (Mustang and Capri) should be 255. Trying to think if the C4 would have been used in trucks at that time. Full size cars would probably be getting the AOD (it was introduced in '80).
Early 80s were a very bad time for the US auto industry. Low quality builds and patchwork engineering. Lots of stuff sold to consumers where were the engineering test bed. Most of that stuff didn't pan out in the long run. Some of it was a really good idea, just not executed very well.
broncnaz
The 255 is fairly easy to ID as the intake manifold will look funky. its sort of a open runner design with a stamped steel valley pan under it like the old Yblock engines. Also intake ports will be round instead of rectangle like a 302.
Living life at 8000 feet don't waste money upgrading the intake and carb upgrade to fuel injection. It will save you money from tossing out the carb and adding fuel injection later.
la hi
la hi
I have the engine up on the engine hoist. I have removed the PS, A/C, ALT, STARTER, FAN ASSEMBLY, etc. on the front. I am having a problem with the nuts on the fly wheel holding the converter on.
I can not find a block casting number???? Not above the starter or anywhere else.
I have the 4v intake casting number E4 TE 426 BB. Can you help me with what engine I have??
I still can't post pictures!!!
la hi
la hi
OK! I put the engine on the stand, took off the 4v intake manifold and stamped on the block was 351 WCP20. Now that sounds great, but what do I have?
Look at the block just above the starter. What numbers are cast in at that location?
More than likely you have a 351W. But need those numbers to know.
la hi
la hi
There are no numbers stamped on the outside of the block. I have scoured it to find them.
la hi
la hi
thanks for the great help all. I am off this thread and will move forward with converting a 170ci six to the 351.
