377
Quick question can a regular 302 timing chain cover (with port for mechanical fuel pump)be used with an explorer water pump? If not can the explorer cover be used with a double roller timing chain. Thank you in advance for your help.
Wrong. The explorer tc is unique because it lets the impeller sit inside it. And the bolt pattern is a little different
Someone deleted a post. The one i was responding to said all 5.0 and 5.8 tc's were the same and offered a link to prove it. I dont know where that post went but it made me look mean. And i swear im not.![]()
Check the balance on the crank of that engine. A lot of the scat and eagle kits are older style 28 oz. This means aftermarket balancer with spacers to work with explorer front dressWhat I'm looking at is a Blueprint 347 long block. In the photos of it there is a timing chain cover with a port for a mechanical pump. I am going to run an explorer front dress minus the exploder power steering pump and bracket. Being using the WH Saginaw kit for power steering part. Running EFI so the mechanical fuel pump isn't relavent. All I needed to know is if I could run the included timing chain cover with the explorer front dress. Which sounds like a negative. One question that is about as stupid as my first question,reverse pattern. That is dictated by the explorer set up/belt routing,etc correct?Thanks again guys.
