306 Blueprint with Holley Sniper Issues
Beer and Fish
So I got my engine in and am very happy with the performance and results HOWEVER Sunday I pulled the Bronco out of my shop to give it a bath and I was very careful not to get any insides or under hood wet. Coincidentally, I started the truck and it was super choppy, almost lean-like or complete misfire on multiple cylinders. Chugga Chugga Chugga and never got better. I tried over and over to make it right checking distributer cap for moisture, checking spark plug wires etc. I have a Holley 556-152 Coil. Any ideas on what is happening here? The motor has less than 200 miles on it. It went from being a performer to limping out of the driveway! What gives? Holley Issue? Blueprint issue? Coil Issue? 02 issue?
BLUEPRINT ENGINES PLEASE CHIME IN
Eoth
Just shots in the dark.... Only thing we know is that a new engine it is running rough after sitting for a bit. Got to start eliminating things. Start with the basics.. Fuel, Spark, Air.... Tell everyone how you checked each and why you think it is good or bad. I could guess what the issue is, but it could lead you down a dead end and waste your time.
Beer and Fish
Beer and Fish
most likely a fouled plug thing. First 500 miles or break in according to Blue Print Engines. We will know in a day or two. Doing some other stuff too!
BluePrint
Glad to help, sounds like you called in. I would agree, that a fouled plug is probably culprit #1. Is this EFI or Carbed? fuel pressure is also important with both. Usually calling in with serial# is the fastest way to pinpointing, so sounds like you have done that and are on the right track. If its EFI, and has a bunch of cold starts on it with no, or very little drive time, it can fould plugs fairly quick.
You're welcome to try NGK BKR5E/7938 plugs. they are a little hotter.
RODRIG3911
Tucson
I'd download a Sniper datalog to see what I shows... Maybe post a log on here and we can check it out togehter
