306 build intake question
P
pennyduke
Stafford
On the 1970 Bronco (6 cylinder swap) does the 302 water pump inlet go on the passenger side or drivers side? I read that 1970 is the year that Ford switched the drivers side. My 302 is a 1971 out of a pickup and I can't find the old pump to tell what side it was on. The one I bought today has it on the passenger side but I just want to be sure before I buy a Radiator for it too. Thanks
In general, you get an early bronco water pump. Which were always on the passenger side. But depending on what timing cover you have, what timing pointer you have, what pulleys you have, what crank damper you have, etc. Sometimes even what steering box you have. It can be easier to use a driver's side waterpump inlet.
It's not set in stone, there is a lot of flexibility in how to make it work. As for '70 being a change year, it probably was, on some applications. But not all of them.
pcf_mark
Plenty of responses on the intake - my opinion is always use a dual plane when dragging around a heavy truck.
As for the Thumpr - DO NOT BUY THEM. I have taken two OUT of cars for owners and replaced with a conventional cam (one fla tappet another a roller) and both owners left much much happier. They sound great but you can't tune them for crap because the intake vacuum is low and the intake charge is polluted with exhaust overlap. Such junk and they do not make any power. Bottom end torque is gone and no top end power at all.
Junk junk junk.
