347 vs 408
KyleQ
thats funny.
the 347 will be way cheaper over all as your 302 parts will bolt on.
the 408 will make more torque but do you really need it? a well built 302 will overpower most broncos and a 347 will be a beast.
Stroking 302 is for retards - its all about low end torque. If you complain about having to buy a new distributor and intake hp/tq must not be for you...
73azbronco
347 vs 408, both are great motors.
When you discuss the 302/351 base blocks in a Bronco, remember, a 351 will require massaging to get it to fit. It is definitely NOT a drop in and go like the 302 block. My 351 left head just touched the firewall, I was lucky in having a drop base intake so the hood fit. The oil pan needs to be special, 351 intake needed, pulleys, etc.
Now, those saying it's retarded to stroke a 347 and DROP IT IN place, have a point if they have a full up operation to do the modifications. Good for them. The rest of us living in the real world without welders, paint booths and such, get by- by adapting known entities to get known results.
Absolutely, a 351 stroked to 408 will out torque a 347, it's common sense, more uncommonly it's called thermodynamics. It may even cost less, depending on sales.
But a 347 will drop in, bolt up, and most likely cool with stock cooling parts, where a stroked 400CI motor may give you fits.
The comment of using 302 parts gets you 302 power also applies to a 351, use a 351 head and intake on a 408, you get 351 power.
Lets stop the childish petty harping on how bad one stroker is over another. Lets help the guy answer his question: what does he want? My guess is he wants to be able to say Stroker, keep it simple, and have some fun., His best option may be to go 347. if he wants to add time and effort, not much but effort to go to a 351 based block, a 408 may be his best option.
Most importantly, get a camshaft that will give you what you want, followed by heads and intake to work with the stroker kit and rest of parts to get the power you want where you want it. Hint, you most likely want power from idle to about 4500-5000 RPM.
Be happy folks:)
A 351 requiring massaging to fit? Late model 5.0s are harder to fit than a 351.
73azbronco
I'm talking only the block, a 5.0 with EFI has it's own issues, good and bad.
Plenty of threads on installing 351's and issues involved, yes, manageable, but issues.
My specific 351 had a PO who smashed the firewall with a hammer to gain clearance from the head and valve cover, the throttle linkage was bent to make that work, some have issues with hoods, etc.
302/347, bolt it in where it was removed, go drive. I'll be the first to admit, a 351 is easier, but if your talking 408 vs 347, a 302 based block will be an easier install.
G
golfobx
Suffolk, Va
Hp and tq
347 415/415
408 425/455
For the troubles of installing the 408 are the gains noticeable enough to warrant the time and money invested? And to be clear, guessing around $1200-1500 more for the 408. Not so much worried about the time.
Things that I know would need to be done. Body lift. New intake. New brackets for some things. Not big deals.
Something that has been mentioned which concerns me is the overheating aspect. I have a brand new not yet installed WH staggered 4 core. Would that be sufficient?
Again. This is a toy. I want to go out and make noise and have a good time with my friends. Am I street racing a bronco, no. Do I care to say I have a stroker, no. Do I want something fun and entertaining, yes.
Everyone's opinion is appreciated. Thanks for taking the time to weigh in.
EricLar80
You can't just take the two peak numbers at face value and use that as your only comparison. The 408w will produce more torque over a wider range of RPM, which means it will also produce more HP at a wider range of RPM.
347s are known to be rev crazy (lower rotating mass, so it will spin up quickly), and that makes them feel more peppy all things considered equal. The 408w won't be a slouch, but just different. Higher compression ratios will make the engine feel peppy.
I am a fan of the stroked 351w series of engines. I personally think they are more reliable for a given torque/hp, and that power is down low where it is more usable for Broncos.
Eric
sykanr0ng
The 347 can use the block that you already have or one identical in outside dimensions.
That makes it the easiest to fit to your Bronco.
Since nothing that you plan on doing with the Bronco requires more power than a 347 will produce it would be the better solution.
Before you argue otherwise read post #8 where he tells what the intended use of his Bronco is.
He is not building a crawler or a race truck.
G
golfobx
Suffolk, Va
So for my knowledge. I have read a lot on getting the 351 in a early bronco.
But other than a body lift and a new intake and moving some mounts for power steeringn and alternator. What else really has to happen?
Would a brand new 4 core radiator keep it cool enough?
What are the major obstacles here that I am missing. It seems most people are leaning towards the 408 being the right choice for me. But I'd sure hate to make the wrong decision at this point.
Gurus please chime in.
Mountain Ram
Recovering Masshole
Abingdon, VA
That statement is a little strong... I enjoy my 347efi for what it is. I had all the components in the rig for 302efi, I bought another 302, so I could keep driving it while I built the 347 and then swapped everything over to the 347 and dropped it in. I am happy and did all the work myself including building the engine, so I cannot possibly be a retard.
That being said- my '70 crawler has a 351w in it, but I am not worried mods to make it fit and I needed the torque to push the C6!!;D
G
golfobx
Suffolk, Va
The brings in another question. I am running a c4. Is that gonna get destroyed by either of these engines.
OX1
The stupid high low end torque of a 408 will have a much better chance at tearing up drivetrain components than a 347. The good with the bad, just the way it is.
But with your intended usage, you may not be "into it", often enough, with enough gearing or traction for it to really matter.
Bronco_69
Monette Ar
to swap from a 302 to a 351w and reusing everything that you can, you will need at minimum
1. 1" body lift
2. intake
3. distrubutor
4. oil pan
5. front accessory brackets
6. longer push rods
may need
1. headers
2. exhaust work
3. hood scoop or larger body lift
4. most likely need a new carb going from a 302 to a stroked 351w
5. your gt40 heads would be junk on a stroked 351w
the c4 will live for a while but i would have it built while you have the engine out. even then if you use the new power to the max something has to break sooner or later. thats jsut the way it works. ive torn up c4's, dana 44's, 9" rear ends and more. most of the parts were 40 year old stock parts that i replaced as i damaged them. thats the way this works ;D
G
golfobx
Suffolk, Va
Well a lot of that is already taken care of if I buy the crate engine. All it is lacking is distributor. Intake. Water pump.
So only changes I would need I take it would be body lift.
I have read a lot of people not having room at the firewall. Is this a common problem?
How about the heat issue, is the new 4 core sufficient?
G
golfobx
Suffolk, Va
Also what's the high end power like in the 408?
If I mash it while going 40, is it gonna throw me back in my seat still?
Or is all the power low end?
Bronco_69
Monette Ar
most cooling issues are fan / shroud related. that radiator should be plenty
i would also make sure that the 351w block is set up for a roller cam. no way would i use a flat tappet cam
WheelHorse
By the time you'll hit 50 mph you'll be out of RPM LOL.
Not! If you mash it at 40 she may kick back to first or at the very least, second and kick pretty hard, unless you're turning 44's.
73azbronco
Hp and tq
347 415/415
408 425/455
Be careful with those numbers, is that with a truck camshaft or a street/strip camshaft? You do not want a 6500RPM motor. I mean, you do want that, but the bronco won't perform well with a cam that cannot support low end torque to get the truck moving. My research showed a cam that can give you off idle grunt, most often runs out of juice in the 4-5000RPM range. Which is fine. If your spinning 5000RPM, you will drop most drivetrain components first trip to the dirt/rocks. If you just stick to street, the parts will probably survive just fine because the rear wheels will let loose before the parts are overstressed.
Ahhh, good catch, cooling. Folks fail to understand the Bronco was pushed to it's cooling design limit with the 302. So stick a 347, 351 or 408 in there, and unless you increase cooling that much more over a 302, you will have issues at some point. But again, if this will never hit the hills, or hi speed down the freeway, or have air or an automatic, it probably wont get to hot.
You make mention of C4 being your choice. That will work with either motor, but you need to build it to work with either motor, and it is one reason I went to an NV4500, no worries on cooling, and after the Earth cools from the next big bang, the NV4500 will still be under the truck.
It's sounding like a base 351 with aluminum heads and intake might be your best bang for the buck. Also, would not really need any C4 work other than maybe a light shift kit. My old tired torino 351 in my bronco could light em up all day long. It had a C4, left a trail of oil, it did get hot here in AZ around town, but that was a great excuse to go stroker:)
One last point, go look at Ford strokers, they are the experts and reliable (they made my custom camshaft for my 347), I never heard of the company you mentioned, and I looked at many a company before I dived in. Again, I think a stocker 351 would be best for your use, least pain, most gain.
Bronco_69
Monette Ar
