Quick off the line in a 4500 lb vehicle ... you need torque and proper gearing.
The 408 will top that discussion, but not end it because now you will chasing all the weak links between the motor and the contact patch at the tires. Tranny, transfer, differentials, axle shafts, (front , rear and shorties),u joints, hub locks .... etc
I have not ran it yet , but....
I had my 347 custom built for $5500 locally.
Trick flows, roller block from an explorer , roller rockers... will have Explorer EFI.
I had three different cam manufactures spec a cam for the engine/vehicle/drive line combination and they all came back with very similar suggested cam profiles.
They knew I was looking for torque.
I went with the Comp Cams
35-351-8 (XE270hr-14)
My belief is this cam along with the long runners of the Explorer/GT40 intakes and the heads, should make for a beautiful match up for a torque motor. Due to the fast ramp rates of these XE cams , the intake charge velocity should be outstanding. The exhaust via the head flow , headers and a free flowing exhaust system will take care of itself.
The lower XE cams in the 302's have had outstanding results.
But since my Bronco is in pieces at the moment, only time will tell for sure.
I chose a 347 over a 408 because I intend to run a lighter duty drive line and didn't care to upgrade everything behind the motor to withstand the brutal amount of torque a 408 can create.
I chose the 347 over the 351 just to ease fitment issues, but really they are a minor concern,especially if you do a body lift.
People that freak out over the 347 rod angles usually gush over the venerable Chevy 383 ,which has even harsher rod angles... go figure.
The early 347 had issues because they were one off "home built" versions. The flaws have been engineered out now. There are a lot of long lived 347's out there.
Some argue the 351 internals are beefy as hell, they are. Others argue that they will rev slower than a 347 because of that heavy beefiness ....
Others argue that the new 347 internals are plenty stout and they will rev faster than a 351.... your call.
Like I said, I went for "302 ease of fitment" and have full faith in the newer 347 kits.
I forget which brand mine is , i'd have to unbury the info packet. But it was one of the name brands , well respected kits.
My tranny will be a nv3550, but I,d also consider a 4sp auto overdrive also. (700r4 or 4r70 etc etc)
Final gearing will be decided after it runs, but with 33's and OD , even 4:56's are acceptable according to the charts.
