Man that looks really tall, I hope it clears the hood. Looks great though!
Looks like an expandable rubberized freeze plug...@kman67 what is the plug you used for the PCV on the rear of the intake manifold?
Is your picture from a used cooling tubes or brand new? I have never seen them apart like that...
So if you go with the Mustang tubes, one of them is 3/4" at the rear discharge. Easy to adapt with a bypass hose like the one from the water pump to the thermostat housing. Drops it down to 5/8", built in 90* turn and almost perfect placement for the heater control valve.![]()
Great! What model vehicle did you pull it from?
