4.6L . Question.
Pa PITT
Stephenville TEXAS
OK this question is for my Running Buddy . He has a 1966 Bronco with later V8 and AOD. already going.. BUT HE has found a 1997 Lincoln with a 4.6 and auto he says it's a AOD. ONLY HAS 50,000 MILES on it and hit in the side. Can this 4.6 & auto be installed into the Bronco . or is it to tough to get going. I thought several had tried and gave up. Due to computer issues. But the shop says it can do the job and has done some good work for him in the past.
... Do you think this is a good swap .. Half the reason he wants this is so he can get AC on his Bronco & and a new Wiring setup.
... Shop wants $2000.00 for the motor & trans ..Then $1500. to do the install . Which includes the wiring harness labor but not the cost.
.... Give me some ideals.
Todd Foss
Doable
I installed one out of a 95 mark viii last August. But the tranmission should be a 4r70w.
I used motor and transmission and have put 30,000 miles on it, I would do another.
The frame mods are minor.
$1500 is a low ball bid. Shop can't do it for that. Maybe a hack install, but nothing you would want. They don't even know what the transmission is. It is not an AOD, it is a 4R70W. The adaptor to attach the transfer case to the transmission is around $600 on a good day and typically lists closer to the $700 mark. And the transmission needs a complete tear down to install it.
There are a few different lincolns, being the AOD comment it would have to be RWD, my guess is a town car? That would be a boaty 2V motor. But they did do some 4V motors in the sportier models (I am not a Lincoln expert, sorry). $2k sounds like a very steep price as well. Many of us are buying whole running driving cars for way less then that just to get the engine and other stuff.
Harness, as far as I know there are no drop in 4.6 harnesses. So when they state "plus harness costs" that could easily be in the 4 figure range as it would be a one off custom piece.
As for the 4.6, it isn't a drop in. There are a few that have been done, but I can't call it common. It is a custom install and will require a lot of time and engineering to get it in right. The numbers and statements are not adding up right in my book. I would pass on this option.
dnewman9
I have done it, the modifications are extensive. You will need motor mounts, custom harness, headers, a custom starter or frame mod, and if you want AC you will a have to modify the front passenger side frame gusset. If you go the DOHC route column shifting is a challenge, power brakes is a challenge and if Mark VIII the IMRC mounting needs to be swapped over to the Cobra style.
My truck runs good the 4r70w shifts great. It is comparable to a late model 5.0 swap I did a few years back. If I had it to do over I would consider a 351 EFI motor or maybe a 5.4. I am contemplating converting my 4.6 over to a supercharged cobra version but honestly with such a short wheel base, soft suspension and high center of gravity I am not sure I need 4-5 hundred horse power.
BTW, I am running 4.11 gears with 35's I think the sweet spot for gearing on this combo would be in the 4.88 range. That may change my impression of the motor.
Dennis
trailpsycho
I believe Ford is now offering a 4.6 EFi harness and computer swap kit for the 4.6 and 5.4 motors for ~$1500.
Pa PITT
Pa PITT
Stephenville TEXAS
Man I don't think I'm liking the sound of this swap.. Running Buddy an I haven't got to spend as much time together this summer a normal.. He has His Business and is city counsel man and a church leader .. And every thing else in town .. A very busy man.. So I try to get the best answers I can for him. You Guys provide a lot of answers for us...
.... Best thing was last year while Hunting in New Mexico for a week neither of our Cell Phones would work .. What a shame..
..... So Keep any commetts coming .. His Bronco is running good with the 302 & AOD but it does need a wiring harness.
Pa PITT
Pa PITT
Stephenville TEXAS
We had supper together tonight .. It sounded like he's about talked himself out of it.. He talked to someone who had done several of these swaps . Information gotten from one of the Bronco Vendors. After visiting for 45 minutes I think he's back to looking for an Exploder 5.0L set up. He has an almost new motor in it .. Just needs to go to the EFI sey up. But he wants AC BAD.
