4G Alternator Problem (Or maybe not)
jimschulz
Eastern Washington
I am questioning wether I may have an issue with my wiring. I have converted to the 4G alternator from an explorer. I connected wire 904 to the I terminal, the battery lug to +Battery and the A terminal to +Battery. I have not started the engine yet, but had my ignition in the "on" position to test relays and FiTech ECU. Everything is working as expected except I noticed there was a slight whisp of smoke or something that was hot coming from the voltage regulator area in the alternator. I put my hand on the cooling fins of the regulator and it was hot. The smoke didn't smell electrical, rather just a hot smell. This is a new alternator and could be burning oil or dust off the fins. I have since tested it several times, and no more smoke is visible, but it still gets hot around the voltage regulator fins. Should this be getting hot? especially when its only sitting with the key on. I have metered the leads and have 12v at the battery lug, 12v at terminal A and 12v terminal I when the key is on. when the key is off terminal I drops to 0. Any thoughts?
Viperwolf1
electron whisperer
Sounds normal to me. With 12V at the "I" terminal the field coil is energized through the brushes. It's bound to get warm with no air flow.
jimschulz
jimschulz
Eastern Washington
Thanks for the input Viperwolf1. I think it must have been grease and dust evaporating. The wiring for the 4G is so simple I didnt think I could have got it mis-wired.
